Engagment Issues...let me know what you think
Location: Grand Rapids, MI : Milford, MI: Flint, MI depending on the time of the year
I just did a manual trans swap over labor day weekend. I put in a new clutch and the 21,000 miles old hydraulics and transmission. I got the setup from a wrecked car. Now my problems started one week after the swap. My car would not go into gear on one random morning. After pumping the clutch a few times and a few ignition cycles the car started working again. So that evening (a few days ago) I decided to try and bleed the clutch again. After bleeding again, my car would not go into gear again this morning. After lettting the car sit for a few hours I pumped the clutch pedal and it made a squishing noise. The pedal has pressure but does not come all the way back up. It stays down about an inch. As of now the car shifts but only with some force and perfect rev matching. Do you think I need to bleed the clutch more??? Can an air bubble cause this? or is it more likely a faulty slave or master?
I plan to take it to a dealership tonight because I am 200 miles from home. If you can offer any thoughts I would appreciate it.
Thanks for the info guys. I will try to bleed with the rear of the car up because I have done it twice with the front of the car in the air. I used a mitty vac to bleed the master and then I hooked the master back up and tried to bleed the system using the pedal to the floor, open then close, let the pedal back up.
Yeah that is how I started bleeding the system and then after doing that for about 6-7 times I started doing the pedal on the floor stuff. I will try again. This bleeding shiz can get frustrating. Thanks for the help.
any chance you may have left the bleeder cracked open, or have a small hole in the line somewhere? Just seems weird to me that air would be getting into the system without there being some damage to the line somewhere or a small brain fart like not having the bleeder real tight.
Not accusing, just thinking outside the box.
After bleeding again with mity vac I am confident the system has no air in it. However, my issue still presists. When I go out to my car in the morning the pedal has sunk down and is hovering about an inch off the floor. I think it seems obvious that I have a leak but is there a way to know if it is the master or the slave. I checked the resivor (fluid level appeared fine) and for puddles under the car and both came up negative. And yes the bleeder screw is very tight.
For the record. I had to replace all of my hydraulics and now the transmission bleeds easy and works flawlessy. My slave was BAD! Thanks.
