Weird Tranny Issue...
Every so often my T56 transmission will only shift into 1st, 4th and reverse. But after driving it a bit or after I stop the car and start it up I can shift flawlessly through every gear. Is there any specific issue that causes this?
The solenoid is disconnected? Do you have a resistor bypass, or does your ECM have a service code? (I'm not aware of any "sensor" for the CAGS)
If the solenoid is unhooked and you have an eliminator resistor for the ECM, then no, it shouldn't be extended out to block the 2/3 shifts.. (What about my 5,6 question?)
Have you changed the fluid recently? If not, you may want to drain/inspect the fluid, and try a fresh fill of DexIII. Do you have an aftermarket shifter? If so, verify that no shifter stops are interfering with the shifts.
(Re)bleed the hydraulics, and check the clutch for full (dis)engagement. If nothing helps, start thinking/planning/saving for a rebuild..
Here is a pic of what I have disconnected. I just have the sensor disconnected, not the whole solenoid. I can hit 1st, 4th, 6th and reverse. For some reason I can't find the part of the harness that connects to the reverse lockout solenoid. Either the prior owner removed it or it was cut somewhere for whatever reason. Is there a replacement part number for that part of the harness with a pigtail?
Speedo is hooked up but jumps all over the place. I think it's time for a new sensor.
What I've noticed though is that at idle the car will not go into 2nd, 3rd or 6th. However... if I jump the throttle above 3,500 or so it shifts flawlessly. Once I'm in 2nd I can go from 2nd to neutral as many times as I want but as soon as I shift from 2nd to 1st I cannot get it back into second. I'm not sure wtf could be causing this problem. Any ideas???
I've had a problem similar in my Trans am. On occasion while cruising and i come to a stop and I try to go from 3rd to 1st gear it won't wanna work with me or I struggle too get it into the desired gear. Its only happened twice in 3 months but I simply don't understand why it does that. Transmission solenoids stuck in place in our tranny's?
I think mine is definitively speedo sensor related. Mine works "most" of the time but sometimes it will bounce or go straight to zero. When it reads zero or isn't functioning that's when I seem to have the problem. I'm going to replace the speedo sensor and diagnose from there.
