Another emissions question...
I am going to have my car emissions tested shortly. I Don't have any emissions equipment on the car at all, and I have a cam in it. I had the dyno tuning done by speed inc. Where can I go to pass for certain?
Thanks.
Thanks.
LS1Tech Administrator
Received 1,794 Likes
What's up?
You will be facing nothing more than an OBDII scan at any test center in IL. If the PCM was tuned properly, you will pass without issues. Just do a quick scan of your PCM with an OBD scan tool to make sure all the readiness tests are complete.
Originally Posted by RPM WS6
What's up?
Thanks for the input, I will pre-scan the car before I go on sat. Thanks Ryan.
WHen you say don't clear/reset the PCm what exactly do you mean ?
Let's say I'm getting ready to go for testing and my car throws a code. If I clear that code are you saying I will fail the test ?
I plan on installing long tubes with an ORY soon. I'm having custom tuning done to remove the rear o2 codes from programming.
