Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
Got the cam in this weekend!!!
Old 08-08-2005, 07:30 AM
SgtB's Avatar
Default Got the cam in this weekend!!!
Oh man does that job suck....$1000 labor is what most shops charge and I'll tell you what..it is worth every penny of that.
Anyway, Thanks Matt, Chris, and Mike...
Mike I got the valve springs done about 1/2 hour I got off the phone with you....
Well, I had to raise the idle screw up 4 full turns(all the way up) so when it is in Park or Neutral it is idling at 2grand...but when it is in gear and I am sitting at a stoplight it idles about 950....I know I need to get this thing tuned I just don't have the money right away. If anyone has HP Tuners that can help me out for the time being so I can get this thing to idle better I would really appreciate it.
So for everyone who has asked the question.."Can I do a big cam with a stock converter?" The answer is yes you can....
Holy **** does this thing make power and it sounds like a beast.....it gets really squirrely at a 30 mph roll when you punch it.
Old 08-08-2005, 08:42 AM
Retired Street Racer
Matt D's Avatar
glad to hear it came out ok. we will be out at 4 corners in downers grove again this friday night. you should cruise up there.
Old 08-08-2005, 09:38 AM
SgtB's Avatar
yeah I might stop up there depending on what time I get out of work...I have been working overtime everyday lately.
Old 08-08-2005, 09:43 AM
baddogz28's Avatar
Glad I could help. What cam did you do?
Old 08-08-2005, 09:47 AM
SgtB's Avatar
Mti X-1
Old 08-08-2005, 04:09 PM
RedHardSupra's Avatar
if you want any tuning help, we should get together one of these days. i'm moving to california at the end of the month so i don't have too much time, but i'd love to take a crack at it, as i have some new idling tricks/tools i'd like to try out
Old 08-08-2005, 04:38 PM
SgtB's Avatar
Sent you a PM
Old 08-08-2005, 04:42 PM
gettinthere's Avatar
2000 rpm idle?! Jeez. Glad to see you're enjoying it though.
Old 08-08-2005, 05:08 PM
SgtB's Avatar
Only in park and neutral..at a stop light its was at 850 this morning but its slowly getting lower now that the computer is learning the cam.
Old 08-08-2005, 05:35 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,110 Likes on 728 Posts
Nice... Did you change the oil after doing the swap?
Old 08-08-2005, 06:18 PM
8 SEC SLOPPY SHOT!!!
tuff's Avatar
[QUOTE=SgtB]Oh man does that job suck....$1000 labor is what most shops charge and I'll tell you what..it is worth every penny of that.
Damn what the hell were they going to do for a grand? Hope that includes parts. As for the idle you said you turned it four turns in,that seems like a lot.When i did chis cam i turned it maybe one turn but i reset the tps so it doesn't dump fuel.Did you reset your tps after you raised your idle?That might help you get your idle lower in park.
Old 08-08-2005, 08:14 PM
Import Patrol
CrawlinWS6's Avatar
damn a 1,000 for the install, that is outragous. I paid a shop to do mine, because I didn't have the time and was inpatient. And the shop that did mine even took my heads of, when they did the install and I paid $625.00
Old 08-08-2005, 08:47 PM
Before I got mine tuned it would go from 750-1400. I know how it goes.
Old 08-09-2005, 07:26 AM
SgtB's Avatar
I changed the oil right before teh swap. Everything was used parts except for the pushrods...I am changing the oil within the next couple of days again.
Old 08-09-2005, 07:29 AM
SgtB's Avatar
Well I got the screw down to 2 1/2 turns last night...it is idling at stock rpms...a little rough that low and once in a while I need to footbrake at a stoplight but at least I got the idle in park down...
TPS? I do not know what that is but I wish someone could help me out because I am running pig rich. I get spurts of raw fuel out the tail pipes...
Old 08-09-2005, 08:35 AM
yup! big cams need little air and fuel at idle, that's why people always say to cut 80% off from first 3 columns of the VE table. with too much fuel, the pcm freaks out and changes timing through over- and underspeed, causing surging and hunting. once you adjust your IAC count, get your TPS voltage inline, reset TPS, figure out adjusted values for RAF, get timing down to ~20 at idle, and then of course adjust the idle regions of the VE table, it will idle just fine. you're lucky i got a hpt cable for '01 cars
Old 08-09-2005, 09:47 AM
BADSZ28's Avatar
I can't wait to hear that thing man! You should get with that Supra guy. It sounds like he knows is shizzle. See if you can find a bin file in the repository for a similar cam and mods to get you by.
Old 08-09-2005, 11:45 AM
tuff's Avatar
Marcon knows his **** (redhardsurpra) we have messed with my car a few times.I think he just liked the ride.
Old 08-09-2005, 12:08 PM
SgtB's Avatar
I PM'd you my cell#. When can we get together??
I will buy the beer.
Old 08-09-2005, 12:09 PM
SgtB's Avatar
When you get back stop by....
Quick Reply: Got the cam in this weekend!!!
