5th Gen Camaros, Machinery, Shop Race Car...
Holy crap that looks like a full production machine shop, minus the cnc lathes... I used to run an older fadal at the last shop I worked at. That has to be the biggest speed shop I have ever seen. How many people do you guys employ and roughly how much does this size of shop gross per year in this type of business? Oh ya very clean shop too, and thats one badass drag car.
Thanks for all of the replies!
Thank you for the kind words! We have a CNC lathe as well. We have 30 employees and several departments, but keep everything under one roof.
A little more info since I didn't post pics of the entire shop:
Livernois Motorsports, located in Dearborn Heights, MI, specializes in Ford, GM, and Chrysler late model performance and tuning.
• 36,000 square foot facility
• Installation area with 15 hoists
• Chassis dynamometers
• Engine dyno
• Full engine machine shop and engine build facility
• Fabrication shop
• Cylinder head development center
• Flowbenches
• CNC machines
• Retail parts showroom
• Show quality paint and body facility
In addition to a custom line of in house developed CNC cylinder heads, rotating assemblies, and shortblocks, Livernois Motorsports' fabrication and machine shop can provide a reliable package for a daily driven street car to an all out race car. With the availability of parts from hundreds of manufacturers, Livernois Motorsports can supply you with virtually any high performance product that you may require.
Dealer/Jobber/Wholesale Accounts Welcome! email info@livernoismotorsports.com for details.
Vehicles we specialize in:
Chrysler
300C 2005-Present
Magnum 2005-2008
Charger 2006-Present
Challenger 2008-Present
Jeep SRT-8 2006-Present
Ford
Mustang 1987-1993 (5.0)
Mustang 1994-1995 SN95 (5.0)
Mustang 1996-1998 SN95 (4.6 2-Valve, 4-Valve)
Mustang 1999-2004 (4.6 2-Valve, 4-Valve)
Mustang 2005-Present (4.6 3-Valve, 5.4 4-Valve)
Lightning 1999-04 (5.4 2-Valve)
GT Supercar 2005-2006
F-150 1997-Present(4.6, 5.4)
Ford Diesel Trucks
GM
Camaro 1993-1997 (LT1)
Camaro 1998-2002 (LS1)
Camaro 2010-Present (L99/LS3)
Corvette 1997-2004 (LS1, LS6)
Corvette 2005-Present (LS2,LS3, LS7, LS9)
CTS-V 2004-2005 (LS6)
CTS-V 2006-2007 (LS2)
G8 2008-Present (L76/LS3)
GTO 2004 (LS1)
GTO 2005-2006 (LS2)
Impala SS 1994-1996 (LT1)
Trailblazer SS 2006-Present (LS2)
Trans Am 1993-1997 (LT1)
Trans Am 1998-2002 (LS1)
Mercury
Marauder 2003-2004
Dyno Services
Livernois Motorsports provides three dynamometer capabilities to dyno tune your vehicle or engine.
Our load bearing Mustang Chassis Dynamometer can handle speeds over 200 miles per hour and over 1700 rear wheel horsepower.
The Mustang Dynamometer allows for accurate tuning with integrated air/fuel and boost monitoring under real-world loading conditions. This means a safe tune with plenty of power.
Our portable Dyno-Jet Chassis Dynamometer can be used at our service center or set-up at your location. This system is accurate, easy to use, and very popular with car show organizers and car clubs. The mobile Dyno-Jet is available to rent, through Livernois Motorsports, for your next event.
Our Super Flow Engine Dynamometer can handle up to 2,000 horsepower and 10,000 RPM. Used on everyday street engines, to full blown race applications, our dynamometer specialists can maximize the performance of your engine before installing it into a vehicle.
These dynamometer capabilities allow Livernois Motorsports to sell combinations that work.
Machine Shop Services
• Engine Component Balancing
• Cylinder Block Preparation
- Milling
- Boring
- Honing
- Align Honing
- Clearancing for Stroker Crankshaft Assemblies
• Connecting Rod Reconditioning
• Piston Machining
• Custom CNC Machining
• Cylinder Head Machining
- Milling
- CNC Port Machining
- CNC Valve Seat & Guide Machining
• Specialty Services
- Cryogenics
- Coatings
Engine Build
• Short Block Assembly
• Long Block Assembly
• Complete Engine Assembly
Cylinder Head Services
• Valve Jobs
• Valve Guide Replacement
• Assembly
• Flow Bench Testing
• CNC Porting
• CNC Valve Seat & Guide Machining
• Hand Porting
Vehicle Transportation Services
We realize that many of you are quite a distance from our Dearborn Heights, MI location and have interest in our services, but are not able to make the drive due to work and busy schedules.
We have a single vehicle enclosed trailer or a two vehicle enclosed trailer if there are two vehicles in close proximity to each other. With this service, you can trust that you car will make it to our location and back to you safely, and with much more power than it arrived with!
Cost of this service is very reasonable, but varies based on a distance and the availability of our trailer.
-Rick
• Engine dyno
• Fabrication shop
• Flowbenches
• CNC machines
Chrysler
300C 2005-Present
Magnum 2005-2008
Ford
Ford Diesel Trucks
GM
GTO 2004 (LS1)
GTO 2005-2006 (LS2)
Mercury
Marauder 2003-2004
Dyno Services
- Milling
- Boring
- Honing
- Align Honing
• Piston Machining
- Milling
- Cryogenics
- Coatings
Engine Build
• Valve Jobs
• Assembly
• CNC Porting
• Hand Porting
-Rick
