Check Engine Light
Check Engine Light
My check engine light keeps coming on with the codes P0137 and P0157. I have already changed out the two front O2 sensors because before this error it was telling me that the front two O2 sensors were bad. Don't know why it is giving me this error? Has this happened to anyone else? Thanks.
P0137 - Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 2
P0157 - Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 2 Sensor 2
Those are rear sensors.... do you have cats? Cat problems can cause 02 sensor voltages to vary too. Check your connections as well.
Edit: can we get some info on the car? Year, Make, Model, Engine, Mileage, Mods, recent maintenance, stuff like that.
I have a 2000 WS6. The fuel pump has been replaced as well as the front two O2 sensors. Their is a pipe that a mechanic just rigged because he said that it had a hole in it and that was normal for these cars. Other then that the car is stock.
If you still have your old front sensors that you changed, which didn't fix your problem, try replacing your back sensors with the old ones just for grins. The codes you have point to the rear sensors, i don't know why your doing anything with the front ones . . .
In short, yes, you need to tune those codes out.
As for the original poster, how many miles on this car?
a diablo can't really "tune out" codes. it can only clear them(unless the new on can as it has been rumored). this means that as soon as the computer runs it's checks the light'll come right back on.
are there any other codes maybe just pending? Most scanners should be able to see pending codes. The shaking could be since your on a basically stock tune (can't really do fuel trims properly with a Diablosport). And headers can make the car run a bit rich so, I dunno - its possible. Easier to have the car in front of me to help. Even better to have a scan tool on it
Because the stock wiring will not reach back where they need to mount with longtubes.
If not, I'm willing to bet you have them hooked into the harnesses for the rear o2's.
If you did use an extension harness, make sure you didn't connect the left to the right and vice versa.
