Check engine light came on
My check engine light came on after I installed longtube headers and muffler upgrade what happened to the computer or is the O2 sensors burnt up. It does have catted mids and a cold air intake that was installed before the exhaust system.
LS1Tech Premium Sponsor
Be sure to report back here with the CODE NUMBER after they scan it. Usually the guys that work there will try to tell you the exact problem and want to sell you a part...when in fact, you might not need that O2 sensor or whatever after all (that's a common one when it says bank x lean or rich, they want to sell you a sensor when it could easily be a vacuum leak or something).
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
yeah, thats the O2 sensor right?
had the same thing on my impala when i got the exhaust done with a custom downpipe, says something about the efficiecy level isnt high enough for the cats or something i think...
