Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Camaro and Firebird How to Maximize MPG<br>Step by step instructions for do-it-yourself repairs.
beest mods to improve MPG?
Someone correct me if I am wrong but if your car can "breathe" better it gets better MPG. SO induction and exhaust.
And my buddy said he got better MPG after he got his tuned as well.
Tune helps a lot. These cars are pig rich up top and can afford a little bit of leaning. And although it makes no sense to get them for any reason but mileage (blah), longer gears will help.
Just remember, with these cars it's all about smiles per gallon
tune will help if the tuner messes with the partial throttle tunning, if not, and they only do WOT tunning, then it will be the same.
good tune up is always best, oil change, air filter change, making sure there is correct tire pressure in all 4 tires. changing the fuel filter. not having a heavy foot. drive like a grandma.
but agreed with lid/lts/exhaust my car breathes a lot better, and i get better gas mileage than stock.
i can see everyones point in not caring about MPG but i understand wanting those mods too. if you daily drive your car it only makes sense to do the cheap easy mods that make your car breath better. they give a little performance and a little better MPG.
Thanks for all the info, I have done all those mods you guys mention. I was just wondering if there was anything else I might have missed, maybe a power pulley? I had the car tuned as well, but I don't know what was changed in the tune.
Wheels and tires
The weight of the wheels and tires will affect gas mileage. On my stock-engined 1998 240SX, I was getting about 400 miles a tank (about 13 gallons at the pump) with the stock cast 16x6.5 wheels and 205/55R16 tires. When I put on aftermarket cast 18x9.5 wheels and 265/35R18 tires, my mileage went down to 300-320 miles a tank.
There are lots of things under the hood that could affect gas mileage. Spark plugs, fuel (premium is recommended for LS engines, right?)... fuel filter, air filter, oil and oil filter. I saw a small (1-2 mpg) improvement in mileage after changing plugs.
Engine internals get coated with a petroleum "varnish" from oil and gasoline after a while. There are additives and treatments that you can run through the engine to clean out the varnish, and that may improve your mileage too. There's a 40+ page threat on LS1.com about oil where people discuss some of this stuff.
