383 Build
Old 03-30-2010, 02:45 AM
redwunz's Avatar
Default 383 Build
How much does it typically cost to convert the LS1 into a 383?
Old 03-30-2010, 09:46 AM
Jon@Texas-Speed's Avatar
A good rotating assembly will run you in the neighborhood of $2000-2500 depending on the parts used. You will also have a couple hundred in block work to hone the cylinders and clearance the block, etc. From there it would be assembly. Here's a link to some rotating assembly options.
http://www.texas-speed.com/shop/item...d=884&catid=88
Jon
