what oil?
what oil?
i just got a 2002 trans am. what oil do u guys recommend? should i use regular or syntheic. its got 77000miles on it.5w-30? or 10w-30? And if i use non syntheic oil will it hurt anything
You could use either, but I recommend using a full synthetic. I used to use German Castrol 0w30 which was perfectly fine, but I am now giving the new Pennzoil Ultra a go, 5w30. So far so good but it's only been in the car for 250 miles. Mobil 1 is always a favorite as well. It's really up to you what you pick, all will probably work about the same.
Here is a great information regarding oils...
http://www.upmpg.com/tech_articles/motoroil_viscosity/
From a small section of the report:
"I can't tell you how many times I have heard someone, usually an auto mechanic, say that they wouldn't use a 5W-30 motor oil because it is, "Too thin." Then they may use a 10W-30 or SAE 30 motor oil. At engine operating temperatures these oils are the same. The only time the 5W-30 oil is "thin" is at cold start up conditions where you need it to be "thin."
I have a friend who used to work at a Toyota dealership. One day the oil guys came and filled up their motor oil tank with transmission fluid. They didnt realize it until the end of the day after doing 50+ cars. Needless to say they had to call all of the customers to come back and re-change their "oil." But apparently it didnt hurt the motors to have Tranny fluid in them for a few miles. Sounds crazy, I know. I would be super pissed if one of them was my car
