Quick and easy question
When installing new plug wires, do you need to place the stock spring things on the plugs on your new wires? They are MSD's if that makes any difference.
I did, just to make me feel all warm and fuzzy inside and feel like my wires were protected...
Then I found out the spark was arcing to the metal shields, so I bought a set of
http://www.designengineering.com/cat.../protect-boots
Now I feel even more toasty inside. No more arc!
Thanks for the advice, didn't use them. Car newb here, but I'm trying to learn how to do everything I can by myself. So I'm sure I'll be asking more dumb questions soon.
Did get 6 of the 8 spark plugs and wires replaced before the sun went down on me today, last two will be the back passenger side .
LS1Tech Administrator
Received 1,493 Likes
I'd leave them off when it comes to aftermarket wires with a different boot design.
I always like to start with #6 & #8 (the two on the back passenger side), I like to get the hardest part over first.
Sometimes the MSDs will have arcing issues (as mentioned above) with those shields. They just weren't designed to work with the MSD style/size boots.
Mine are still on, but that's because both currently have stock wires.
For some reason also all the plug boots on the pass. side are ridiculously hard to pull out. Heck I broke the cable on the #2 wire trying to get it off. I yanked on #6 and it was very hard as well, but it was too dark to continue at that point. Haven't even touched #8.
Another question. How can you tell if the spark plug or wire isn't in right? Will it put on an ses light? I test drove the car for a couple miles and everything seemed normal, but I don't really know what to look for.
If the plug wire isn't making contact with the plug, you'll have a nasty misfire that you'll feel, and probably see a flashing SES light. Then, when you scan for codes you'll probably see a P0300 (random multiple misfire) and a P030x (x= whatever cylinder the misfire is on, 1-8).
If it is missing, that would be an indicator.
Basically, you just have to know... For the plugs, make sure they are snug. Not torqued by the almighty hand of Thor, but snug.
For the wires, you push them on until you hear a "click". One click for wire-plug, and two clicks for wire-coil pack.
Alright cool, should be good then. Not too concerned about the wires, but I don't have a torque wrench for the spark plugs. Just did them hand tight, then a little more with the socket wrench till I couldn't turn it backwards by hand anymore.
I think it's 15-ft/lbs for spark plugs on these heads. So basically about the same as the oil drain plug. I've never used a torque wrench for spark plugs, not even sure how the hell you'd get one in there.
Yes, I've heard of that happening when used with MSD wires. This is not a concern with stock or factory replacement wires though. MSD uses a different boot style/lenght that is not meant to work with those metal shields.
Sweet, got all 8 plugs and wires done. That #8 was quite a bitch, mostly just getting the socket + wrench on there. It was way too tight to get off with my little wrench, had to struggle to get a full size 1/2 inch wrench with 3/8 adapter in there to get enough leverage.
And fuq me, I bought all the tools to do this, pretty much every tool I needed was in my company truck in the ChannelLock 100 something socket and wrench set, even the 5/8 spark plug socket, which I didn't notice till I had to grab it to figure out how to get to the #8 plug.
