Engine Coolant Temp. Sensor
I put '01 241 heads on my 98 camaro. My car has a 3 wire plug for my engine coolant sensor and the new head takes a 2 wire plug sensor. Is there an adapter so I can use my factory plug and a 98 sensor?
Would splicing in a 2 plug wire pigtail work if I used a 99+ coolant temp sensor?
LS1Tech Premium Sponsor
Just move your '98 sensor over to the 241 heads and saver yourself all that headache! They have the same thread size so your sensor will work perfectly.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Make sure you're trying to put it into the correct hole also...that hole was the same size for ALL of the LS1/2/6/92/etc heads! So unless yours was machined out or something (can't think of a good reason why that would be the case), it should work perfectly.
__________________
Well, I checked again today at Oreilly's and I had them pull a 98 coolant sensor and an 01 coolant sensor and both had different size threads. The 01 was a lot smaller. So I am stumped. Unless they have the wrong part number? Maybe they are pulling a V6?? But other than that I do not understand how no one else has this problem. Do not wanna spend a ton of money and hassle for an autometer...
Just called autozone and they had the same part number for both years... which iknow isnt correct because the plug itself is different.. i guess ill give the dealership a call tomorrow and hope it works out
If they pulled them and they had different threads, they looked it up wrong or it was boxed wrong. We have WAY too many heads coming in and out of here daily not to be sure on this!
__________________
Anytime Glad to help!
__________________
LS1Tech Administrator
Received 1,493 Likes
I think the dealer is the only place that stocks '98 style sensors. I've heard others complain of not being able to get this part over-the-counter from local stores.
