header install HELP!
i just put the headers on but cant get the last bolt (passenger by firewall). clearance isnt the problem. its tight but manageable. but that bolt turns 10 turns fine but then doesnt want to move again. tried backing out and doing it again but same thing same spot. any suggestions?
ok yeah i tried a different bolt and it worked. but now i think i did a step wrong. i take it i was supposed to but the Y pipe on the headers before i tightened them down? i have the Y pipe fully on but i cant get it on the drivers side LT. Do i need to loosen the header or is there a trick to do it without loosening and retightening all the bolts
Is the Y and the headers from the same manufacturer? If not, sometimes fitment can be a little bit of an issue. Wiggle that **** like a stripper's ***; sounds like you're almost there man.
If you are having problems getting the y pipe on loosening the header does help with fitment.
I have ebay lts and pacesetter ory and fitment SUCKS. Had to loosen both headers to get it to fit right
Yeah i finally got it in there. I had to take off the bracket holding the catback to get more clearance and loosen the driver side header. Fits like a glove now! took about a day to complete with my friend helping me get headers on! but now i can say I INSTALLED THEM. makes me feel good. until something goes wrong ha ha
