Cracked ls1 block lookin to swap to a lq9 need advice
Hey guys I just recently found out my engine block is crack at the bottom over the weekend , now I'm lookin to get a lq9 block and swap all my parts over to the new block , but while I have the engine out I was looking to get new heads or cam put in or both if I can afford it Now my question is which type of heads n cam to go with ?
honestly i need advice because , i dont really know what to do at the moment , i just found out my engine block is cracked at the bottom , idk if i should buy a used corvette motor or a complete lq9 motor from and escalade , but idk what i would need to do to drop a complete lq9 in i know i have to change the intake a drive assembly that all i no - p.s your advice is greatly appreciated
LS1TECH & Trucks Sponsor
We need to know more about your car and what you plan to do with it. I would personally go with the LQ9 block because of the potential to take it out to a stroker later on, but that depends on your plans for the car. Let us know and we can offer some more advice.
Things you need to swap over from your busted LS1
-intake, TB, fuel rail & injectors (if keeping the stock intake)
-oil pan, windage tray, pick up tube, dipstick
-water pump, ps pump, alt, balancer
-motor mounts
Things I would do to it if I were you before you swapped it in
-bolt on L92/LS3 heads & LS3/L76 intake
-custom cam
-1 7/8" long tube headers
That right there has the potential to be a ~470rwhp car.
-motor mounts
-custom cam
well i no this place that sells pull out engines i could get a complete lq9 engine from an escalade ,for alittle over a grand now i have prob cant afford heads and cam more parts at the moment, cause im on a budget so what would be my best combo
ex: " headers and intake " heads and headers " etc
my budget, stretching is 3k grand not icluding labor in the budget , so
lq9 motor =1200-1400
headers
i dont know want intake to get , ive been lookin at the ls3 intake or the fast 102 intake what you guys think
headers
Ok guys , so I managed to up my budget to 4k so far this is my options
I could go with an used lq9 pull out motor then purchases l92 heads and l76/ls3 intake and some longtubes or I can go with a ls6 crate motor from one of our sponsors on here what's you guys opinion and why thanks
LQ9 long block ~ $1000
L92/LS3 heads ~ $600
L76/LS3 intake - complete from SLP on ebay for $300 (w/ rail and injectors)
Texas Speed 1 7/8" headers - $479
Holley 90mm TB ~ $380 from Spead Tweakers
Custom gring cam - $425 from Patrick G
Patriot Extreme springs - $275 from Summit
Trickflow chromemoly pushrods - $87 from Summit
Head and cam gasket and bolt kit - $160 from Texas Speed
Your recipe for 460+ rwhp
Hey guys quick question, I'm getting the lq9 motor , the l92 heads and l76 intake with supporting accessories , and headers I'll save the cam for a later date due to the fact I want to get a torque converter with a bigger stall before I go with a cam , what type of power gains will I be lookin at with the lq9 , l92 heads , l76 intake and headers using my ls1 cam for now ?
^^^^x1 Registered User
It depends what size cam u got? I swap all my ls1 parts 2 my LQ9 Witch inclueds Ls6 intake,ls2 oil pump,ls2 timing chain,ls6 heads, I also have a 230 232 cam , LTs with true duals, th350 with a 3500 stall. It dyno 432 RWHP n 407 Tq.
im in the process of converting over to an ls3 from anls1 and its alot of **** people aint telling you about the swap to make it work right like the reluctor wheel converson kit.any just do your home work.
