LS1 5.7L the best spark plugs?
Old 09-14-2010, 10:51 PM
rotas18's Avatar
Exclamation LS1 5.7L the best spark plugs?
I want to do a tune up on my engine and i just want to know what the best spark plugs would be for an ls1 engine 5.7L?? Thanks for your help!
Old 09-15-2010, 08:37 AM
ParkerSS's Avatar
Currently I'm running NGK555's. No complaints. Great plug.
Old 09-15-2010, 09:45 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
I'd agree, if you're not going to be spraying any nitrous or adding more compression via a head swap or similar, then the NGK TR55's would be perfect for you!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 09-15-2010, 10:44 AM
jb7241986's Avatar
I stuck with factory gm plugs, ac delco platinums i believe. No complaints here.
Old 09-15-2010, 10:46 AM
Wesmanw02's Avatar
For a stock or bolt on engine, AC Delco Iridiums are best. Thats what I run in my car, and they have been great. They provide the best spark due to their fine wire design, and are also designed to last around 75,000 miles, which is a nice benefit.
Old 09-15-2010, 12:00 PM
zachrywd_01TA's Avatar
How to tell you have the Wrong plugs.
1.) Is the plug cheap junk?
2.) Does it have 2 or 4 grounding prongs?
If you answered yes to either question then you have the wrong plug.
Old 09-15-2010, 12:17 PM
TT632's Avatar
There's plenty of good plugs out there. Personally, I prefer nothing fancy since most of the new fangled plugs are just marketing schemes anyway. My preferance has been with Autolite Race plugs with the cut back straps. You can't kill them and they are made in the USA.
Old 09-15-2010, 12:40 PM
MYSTIC-1SC's Avatar
I use NGK plugs in my car.
Old 09-15-2010, 12:41 PM
whtrashferrari's Avatar
Default Ngk!
I second that! just normal tr55 tr6 work great all day long
Old 09-15-2010, 05:08 PM
rotas18's Avatar
OK guys thanks for you help I appreciate it !
Old 09-15-2010, 05:45 PM
zracer323's Avatar
I used to run tr55's with bolt-ons, now tr6's with spray
Old 09-15-2010, 08:59 PM
Black00Z's Avatar
another vote for ngk
Old 09-15-2010, 09:06 PM
kmracer's Avatar
tr55's
Old 09-15-2010, 09:31 PM
Revoroller's Avatar
nkg tr55's is what I run too, no complaints so far after 2.5k miles
Old 09-15-2010, 10:20 PM
rotas18's Avatar
NGK'S G-power, xi-iridium, v-power ? IM NOT SURE !
Old 09-16-2010, 12:08 AM
SonicBoom's Avatar
Just went with the NGK TR-55s prior to having it tuned and it's running beautifully.
Old 09-16-2010, 08:30 PM
Stringfellow's Avatar
Same here, although if I do a head swap or nitrous, then NGKs
Old 09-17-2010, 10:49 AM
hawaiic5's Avatar
NGKs here
Old 09-17-2010, 11:18 AM
blk/slvr02ss's Avatar
I run the new E3 Spark Plugs.
Old 09-17-2010, 12:03 PM
LS14EVR's Avatar
Just put in NGK's person before me put in Bosch Plat +4's and the idle was rough.
Now it purrs like a kitten.
Quick Reply: LS1 5.7L the best spark plugs?
