T56/M12 differences from Vette and F-bodies?
Is there any difference in the 6 speeds in the Vette's as compared to the Camaro's?
I'm looking at swapping my auto for a 6 speed, but want to make sure it goes smoothly. I did searches on here for the M12, but no info.
I know the T56 and M12 have different gear ratios, but I want to know if a Vette tranny will bolt up with no problems to my '99 camaro.
Thanks.
Thanks.
The GTO has an m12 also, the z06 is not the only one with it. If you use an m12 from a GTO you are gonna need to swap the GTO shifter cup for an f-body shifter cup(click on the link for more info about shifter cup). If you use the bellhousing from a GTO you need to use a GTO starter(expensive), or you can modify the bellhousing for your stock starter. In my opinion its better to just buy a GTO starter, they are better starters then the f-body ones. Another choice is to get an f-body bellhousing, that way you can use a regular f-body starter. This is all you need so you can use an m12 on your f-body.
^Thanks. I have been reading on a few different forums to figure this out. There is a lot of conflicting information. But I would imagine using the GTO transmission is probably going to be a better idea, if I decide on an M12.
