Is mobil 1 5W20 ok?
Old 02-25-2004, 06:13 PM
Ashtongsr's Avatar
Default Is mobil 1 5W20 ok?
I was reading in my owners manual ('02 SS) and it suggested 5w-20 oil. I'm about to change my oil and I wanted to make sure it would be fine. BTW, I live in Florida. Also, how many quarts of oil does my LS1 hold? Thanks guys.
-Ashton
Old 02-25-2004, 06:51 PM
SMOKIN01TA's Avatar
-Ashton
use mobil one or royal purple 10w30. it takes 6qts. especially in florida
Old 02-25-2004, 09:10 PM
KrazyDan's Avatar
i think suggest 5w-30. i could be wrong though
Old 02-25-2004, 09:11 PM
Ashtongsr's Avatar
That's actually what i had, i just went to the store and switched it out for Mobil 1 10w-30
Old 02-25-2004, 09:25 PM
SMOKIN01TA's Avatar
stay with the 10/30 the 5/30 dont cut it in the hot south. especially florida.
i think 70% of the people on this board use either royal purple or mobil 1 10w30
Old 02-25-2004, 09:29 PM
Ashtongsr's Avatar
I read in a thread a while ago that someone was saying you can get up to like 10,000 miles on synthetic and that oil analysis concludes that oil doesn't show signs of needing to be changed until around that mileage. Anyone know if this is true? Any links to "oil analysis?"
Old 02-25-2004, 09:33 PM
SMOKIN01TA's Avatar
you dont usually change syntheic because it goes bad every 3-4k you change it so you dont have all the metal shavings and tiny particals circulating in the engine.
Old 02-25-2004, 09:48 PM
TeamZ's Avatar
I live in kansas city missouri and i use valvoline 5w30 should i change to a differant brand? if so what do you guys think i should change too.. also im moving to so cali in the next 4 mths what should i use out their too?
Old 02-25-2004, 10:22 PM
01SSM6's Avatar
the main reasonyou change oil is no because of metal shavings its just the oil gets broken down by gas any condensation etc...i use Royal Purple 5w-30 5 and a half quarts...
Old 02-26-2004, 03:14 AM
Tom@SpeedInc's Avatar
Royal Purple is not good oil and would not recommend it. AMSoil and Redline are the best oils period, Mobil 1 synthetic is very good but still their 5w-30 is a bit thin so with the cold weather we have in chicago I use Mobil 1 0w-40 gives faster starting time and better lubrication on cold starts. The only difference between 5w30 and 10w30 is the viscosity at cold temperature and has relatively no affect once the engine is at running temp. Their was a guy on here "patman" and he knows alot about oil and would probley agree with what i'm saying.
yes their was a oil study done on LS1 engines that showed Mobil 1 synthetic can go 11,000miles. AMSoil claims their oil can go 25,000 miles with one filter change. However i'm quite content with changing my Mobil 1 or AMSoil at 5,000 miles, their radical tests results just give me pieace of mind.
And also don't forget that AMSoil Redline and Mobil 1 are really the only synthetic oils widely available. All other Castrol pennzoil quaker state are just dino based group III oils meaning they are just modified versions of regular oil, this makes Mobil 1 a great value.
Old 02-26-2004, 03:44 AM
Patman's Avatar
Mobil 1 does not make a 5w20, they make a 0w20 though and it's very good but not for the LS1. It works very well in new Hondas and Mazdas though.
For oil analysis results on many oils, click here:
http://theoildrop.server101.com/cgi/...=365&submit=Go
Old 02-26-2004, 06:48 AM
01SSM6's Avatar
i use royal purple because my local engine builder swears by it...hes been using it for as long as he can rember in his personal vehicles with no problems whatso ever so i'll just stick with what i know
Old 02-26-2004, 12:21 PM
KrazyDan's Avatar
ive been using mobil 1 syn 10-30 but my last oil change went with 5-30. living in so. cal. should i switch back to 10-30?
Old 02-26-2004, 12:30 PM
steve2001sh's Avatar
The 02 SS wants 5W20? My 98 TA wants 5W30, which is what I give it. Patman's posts on oil are a must read.
Old 02-26-2004, 01:45 PM
Ashtongsr's Avatar
I typo'd the 20. I meant to say 5W-30.
Old 03-04-2004, 04:19 PM
bill99hawk's Avatar
I use Amsoil Synthetic! Works great for me.
Old 03-04-2004, 04:52 PM
PEWTER SS's Avatar
I like and use Mobil 1 5w-30. I would not use Royal Purple at all.
Quick Reply: Is mobil 1 5W20 ok?
