wiring screw up
wiring screw up
Me and my brother are doing an ls1 swap in my 01 camaro. well we got in a hurry and didn't tag all the sensors. I was wondering if someone has came up with a write up and color codes of each connector. we are about to put the new ls1 transmission and engine in the car and are going to start wiring it up.
Do you have a wiring harness and PCM for an LS1 Camaro? If you're starting with a V6, you need the LS1 engine/trans harness and the PCM.
You'll also need to swap the K-member.
It really helps if you have the donor car the LS1 came out of.
basically all i need to know now, is basically on each head, on the back there are 4 bolt holes..I know on the left side 2 of them are grounds and on the right is the transmission dipstick. what all goes in those spots? i was a dumba** and didn't take pictures of the back or anything. -_-
