is a 6l crank and ls1 crank the same? spacer?
hey guys i know the stroke is the same between 6l and a ls1. but is the spacer able to be removed off the truck crank and used in a truck block for a car. i know there are hundreds of 6ls in cars but do u have to keep the cars crank or can i use the trucks crank and just use a car rear cover and truck crank minus spacer?
oh and on another question can i push the crank to 700 or 750 whp with boost? is that pushing its limits in your opinion. its my daily driver the plan is to get a forged crank but i already have the stock 6l truck crank sitting and rods and pistons sounds better. was giong with a 370 and a bb 76mm
yes it looks removable. so i got the right one for the m6 370 build u think i can make 700 whp on this stock crank and drive it every day spring summer fall. 76mm bb turbo and arround 12psi id imagine.
ok got the spacer off the crank. and its the same as the spacer jegs sells for the adaptor for ls1s to manual trans.
http://www.jegs.com/p/GM-Performance...35483/10002/-1
this is the desc of the spacer on jegs site. its just the stock 6l spacer but if somone needs one then id sell this since its gona sit. the gm one is 42 bucks id take 22 shipped.
