Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Engine Guides
- Camaro and Firebird: How to Change Your Oil
Step by step instructions for do-it-yourself repairs.
How much oil do you run in ls1 and how much is too much?
Just did my oil change with 6 quarts and on the dipstick it reads a little bit higher then the full mark but not by much... should i drain a little out?
Reading the forum i read of some people using 5.5 quarts all the way to 7 qts
LS1Tech Administrator
Received 1,492 Likes
5.5 never seems to be enough to reach the full mark. I usually do 5.75-6, and sometimes it overshoots the mark by a little. I don't worry about it.
I have a 2001 z28 and I use 6 quarts of castrol full synthetic with a ac delco oil filter and don't have a problem I would always want a bit more than what it needs then less then what it needs. From what I have read you really don't have to worry about hurting anything until like 7 which is a lot more than what you need for your car.
Put a tad over 5.5 and you should hit the fill line on the dot, then add the rest after driving it for a while. I always top off oil filter before putting the new one in on any of my performance cars. Probably makes no difference but it does in my head lol
