Anti-Seize?
I got really freaked out while reading threads...everyone said ITS A MUST! Thanks alot guys. I hope it doesnt get stuck in the head. If it does I guess its time for performance heads
I use that stuff on damn near everything but lug nuts. Things have a habbit of rusting up here in New England, so I like to know I'll be able to take it apart later on if I have to.
same here in south texas. the anti-sieze definitely makes things easier to take apart and less headaches, less need for the drill...
LS1Tech Administrator
Received 1,493 Likes
Spark plugs don't need to be excessively tight, only about 11-15ft.lb. in an aluminum head. That's not even as tight as an oil drain plug. You'd have to really tighten the **** out of a plug to snap the threads off as illustrated in that NGK link. Simply using anti-seize will not cause a careful person to overtighten to that extreme degree.
It's nice that they have a special coating but I will continue to use anti-seize without worry, as I do not use a 1/2" drive, 42" long breaker bar combined with Olympic powerlifter strength to install my plugs.
