Any advice on quieting sewing machine noise?
Old 05-29-2012, 11:30 AM
ccdominic's Avatar
Default Any advice on quieting sewing machine noise?
just bought the rx7 and attempting to familiarize myself with the domestic motors as much as possible, so these build sheets are in another language to me. the sewing machine noise is driving me crazy and i could use a little direction on how to quiet it down. thanks guys!
mods are:
  • Stock Crank
  • Scat Forged Rods
  • Probe Forged Flat Top Pistons
  • Coated Bearings
  • Ported & Polished 241 Heads by SLP
  • PRC Gold Spring Kit W/ Titanium Retainers, Seats & Seals
  • TSP Chromemoly 7.40” Pushrods
  • TSP Custom Grind Camshaft 232/234, 595” / 598” , 114 LSA
  • LS6 Intake
  • Stock Throttle body and MAF
  • MSD Plug Wires
  • Stainless Fuel lines from engine to connectors under car
  • Z06 Return Fuel Rail W/Vac FPR
build info:
Old 05-29-2012, 04:06 PM
99Bluz28's Avatar
First find out what lifters it has in it, then buy/barrow a push-rod length checker to find out what you lifter preload is so you know if you're within the recommended range. I'd also check your LS6 intake to see if it has the two foam stips on the bottom.
Old 05-29-2012, 04:19 PM
M1tch's Avatar
My engine bay was louder noticably and i ended up having two loose spark plugs haha check that. But theres alot going on under there thats alot of valve lift so its going to be somewhat noisy man. Get a stethoscope and see if its your idler pulley/ ac pulley or just your rockers
Old 05-29-2012, 04:32 PM
thunderstruck507's Avatar
As mentioned above:
check for correct pushrod length to preload lifters, there are several part numbers which all require different preload
make sure the foam strips are still attached to the intake bottom
check rockers for damage or signs of excess wear
Depending on the cam lobes used, it might not get much quieter. Another thing is experimenting with oils. My engine was noticeably quieter with Castrol Syntec 0w-30 than Pennzoil Platinum or Mobile 1 5w-30.
Old 05-29-2012, 04:39 PM
ccdominic's Avatar
thanks guys! i'll be sure to try all of the above.
Old 07-02-2012, 06:38 PM
ccdominic's Avatar
ok guys. car hasn't been getting much attention. been so crazy busy at work. gonna start gettin her together. just bought a new gauge panel and speakers, but i also need to get crackin on this noise.
if it's nothing that will damage the engine i can live with it, but here's two vid's that display the noise (sorta). the dash and door panels out to get ready for the parts mention. any help would be greatly appreciated guys! thanks again.
if need be i can take our condenser mic and really get a good recording.
startup on warm day
http://youtu.be/m36vGhAOtH0
after a brisk little drive
http://youtu.be/W9uoPwcGIm8
Old 07-02-2012, 06:48 PM
99Bluz28's Avatar
Sorry, the sound is really distorted. You'll need to make a better sound clip for it to be of any help.
Old 07-02-2012, 06:55 PM
ccdominic's Avatar
yea i figured. i'll take the laptop and condenser mic out there tonight. get a good recording.
Old 07-02-2012, 08:53 PM
TyCZ28's Avatar
TWS car Squeaky just had the Comp Cams Trunion upgrade done and the "sewing machine noise thats typical from an LSx motor went away.. His valve-train is much quieter.. However the Procharger is as "squeaky" as ever =]
Old 07-02-2012, 09:00 PM
ccdominic's Avatar
http://youtu.be/0OJCNvqnqsg
this should be much easier to hear
Old 07-03-2012, 02:26 PM
ccdominic's Avatar
any takers?
Old 07-03-2012, 04:00 PM
Lee12609's Avatar
listening to the last video sounds like belt drive noise.
pull the belt and see if it quits. unless its just the video that makes it sound like that.
Old 07-04-2012, 07:59 AM
justin hover's Avatar
As far as my understanding goes...That sewing machine noise doesn't go away..I have it after my lts/duals went in...It's tollerable..but once my cam goes in I'm sure it will be noticably louder...I've read alot threads on this noise....Seems typical with no "for sure cure"...Unless it's a tapping or leak...It's just their to stay
Old 07-04-2012, 11:38 AM
A.R. Shale Targa's Avatar
That particular cam has pretty aggressive lobe ramps which elevates the
common LS1 valvtrain noise. Having quality lifters and proper pushrod pre-load
along with the trunion upgrade on the rockers helps to minimize the insanity.
Also the springs need to be properly shimmed. If the duals can handle .675
lift but your cam is around .600 sometimes they can experience surge unless
they are shimmed(shorter installed height) to within .060" of coil bind.
As some have stated...the engine oil viscosity can change this sound. I went
from Mobil 1 5w30 to Mobil 1 0w40 which is a European blend and apparently
has higher zinc content(similar to high mileage oil). This slightly reduced the
noise; not by alot but noticeable.
Old 07-04-2012, 12:30 PM
MIKEY'S 2002 TA's Avatar
Default noise
that really doesn't sound bad at all. like noted above, it sounds like belt noise. the idler pulleys go bad on these cars. do what Lee12609 said and pull the belt and start it and see if it goes away. it seems tome that the top idler pulley goes bad more often than the bottom. i replaced mine with a manual style.
Old 07-04-2012, 05:25 PM
garygnu's Avatar
how many miles on your engine ?like mentioned above remove and check your rockers for missing bearings.remove all of your push rods and measure them.maybe get some harden push rods that are .025 longer then the 1 that currently in your engine.
Old 07-05-2012, 12:44 PM
ccdominic's Avatar
awesome info guys. i'll be sure to check out all of the above, starting with pulling off the pulleys. definitely appreciate the help.
Old 07-05-2012, 12:50 PM
ccdominic's Avatar
to be honest tho, it the sound is definitely coming from the valve train. the sewing machine aspect is much more audible inside the car.
Old 07-05-2012, 12:52 PM
ccdominic's Avatar
more info?
ccdominic's Avatar
about 88000 on the car. engine was rebuilt about 5k miles ago.
Quick Reply: Any advice on quieting sewing machine noise?
