JP Double Roller Timing Chain
Old 06-15-2012, 08:32 AM
Rtzracer's Avatar
Default JP Double Roller Timing Chain
Anyones experience with the JP double roller? Pros/Cons?
Old 06-15-2012, 09:39 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
We've run a lot of them under the N-Motion name (N-Motion used to rebox them, now they just send them in the JPP packaging). They are nice sets that don't break the bank. Torrington bearings, adjustable, tough....
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 06-15-2012, 01:27 PM
thatoneguybriz's Avatar
Does a JP double roller interfere with the stock oil pump housing or timing cover?
Old 06-16-2012, 12:41 PM
Rtzracer's Avatar
From what I've read, double rollers require some modding on the timing cover. Unless you buy a comp timing cover built for the double roller. Still deciding on which double roller to buy; Comp, SLP, JP.....?
Old 06-16-2012, 02:26 PM
+badss+'s Avatar
I'm using a JP dbl roller on my engine you have to use a dremel to remove a little bit of material from cover to fit not real hard.
Old 06-16-2012, 05:33 PM
I8UR4RD's Avatar
yeah that is what AES uses on their motors. I am working on my cover right at the moment.
Old 06-16-2012, 07:12 PM
TransamGCS's Avatar
if you get the SLP double roller SLP oil pump combo you dont have to grind the cover or use shims
Old 06-16-2012, 09:03 PM
conan's Avatar
I'm running a rollmaster double with a ported LS6 pump. Oil pump is shimmed and it clears the stock timing cover.
Old 06-26-2012, 10:34 AM
Rtzracer's Avatar
So, the SLP double roller and SLP oil pump do not require timing cover modificaitons?
Old 06-26-2012, 05:31 PM
TransamGCS's Avatar
correct
Old 06-27-2012, 01:27 AM
Rtzracer's Avatar
Thanks Trans for the info. That will save me a lot of headache.
Quick Reply: JP Double Roller Timing Chain
