Cam question
Cam question
So i have a 02 Z looking for a good cam to drop in. Now i read the stickies and i know heads and cam go together but i want to put a cam in and then heads down the road. So im looking for a good cam nice rough idle that can mate up with some heads later on down the road. And about how much am i looking for install at a shop
the texas speed 228r is always a great choice. has great power throughout the band, nice lope too. and if you add boost, youll still have a failry reasonable boost cam. that is why i always recommend it. then again if i did it all over again id just go with the brutespeed blower cam from the get go.
I have a M6 with a SLP Lid and a straight pipe running off the stock manis and y into a bullet dumped. i plan to get at least headers before the cam but would like to see what i can do when the time comes
a good shop can do a ls cam swap in 8 hrs.maybe consider doing the swap your self with some help from some friends.go to Texas Speed and look at some different cams.you need to tell them every thing about your car.how many miles are on your engine ?
be patience and save up to get all the parts you will need.you should get some new lifters and some rocker trunnion bearings.get a new oil pump and a ls2 timing chain.you will need a retune if you add heads later.
