buying WS6 friday any common problems to look for?
so im buying a 1999 ws6 with 100k miles on it friday I have been in love with 98-02 WS6 trans ams since i first saw this exact car back in the 6th grade in 2002 and somehow it came up for sale
unfortunately its an A4 car but im still in love with it
are there any issues to keep an eye out for i get to see it friday when its owner gets back from out of town
i believe its completely stock and it doesnt leak anything at all
thanks for any help in advance
Check out the stickies:
https://ls1tech.com/forums/pontiac-f...-1967-2002-73/
Two big ones are window motors going out, and headlight motors eating gears.
Yeah check windows. Check oil pressure when warm. Check operation of everything. Look for leaks. Pinion seal, any oil leaks. MAKE SURE THE CHECK ENGINE LIGHT WORKS. Not just that it isn't on but you see it when you turn the key to on. Mine is covered up and has been since I bought it. The ash tray door. The power seat things work on both seats
check the trans fluid .and try to listen for any excessive valve train noise caused by missing rocker arm bearings.look for any leaks from the rear trans and pinion seals.make sure the coolant is the correct color,if it has a PS cooler they can leak.
check all fluid levels, listen for lifters ticking, look for body panel bolts that have missing paint. paint marks on engine or trans usually indicates it came from a salvage yard. i can tell you already want the car. take someone with you who will look it over with you and see things you will miss.
thanks for the info guys, i do think im going to have to take someone else with me so i dont make a huge mistake as i have little trans ams in my eyes, but now i know what to attempt to look for
A second set of eyes is beneficial I find. Especially if they're familiar with the F Body. One guy can ask while the other is looking etc.
Previous posters have given good advice, nothing to add from me... Oh yeah, bubbling sail panel ( unless convertible haha! )- not a simple paint issue to correct...
All of my cars have lasted to well over 100K miles, because I take care of them. I sold a Cammed WS6 A4 to a board member on here and he has driven it for the last 5 years still has the 10 bolt and the 4L60E in it, I am not sure of the mileage but it had 140K when I sold it to him. 100K miles is nothing to be scared of as long as the car was maintained.
Just go over it with a fine toothed comb and you will be fine. They are fairly easy to work on too
becareful with that 4l60e get you an aftermarket trans cooler and change fluid often..will help it live longer..i've also read a shift improver kit helps as well but never tried it
a lot of bodywork details are bound to occur even if the car was taken care of. For example the window motor, headlight gear, etc... That stuff can be fixed easily. Its the engine related problems you want to stay away from.
take a good look at the roof sail panel... from what im told, '98 on GM had latent defect with there new glue formula and in many cases it starts bubbling and looking like **** especially when exposed to the sun for great periods of time. Also check the t-tops out (if equipped) and make sure they are in proper functioning order.
