weird noise @startup....
Old 04-06-2004, 06:13 PM
wbw2's Avatar
Default weird noise @startup....
hello, please tell me if this is normal or not for a 98Z28,A4, 30,000 miles.
When I start the car, there is a loud whirring noise, I think it is a fan, but it really hums. After about 5 minutes it stops, and does not come back on. The mornings have been cold, so I don't know why the fan would be actuating. I don't drive the car much, and it has done it more or less the whole 2 years I've had the car. Please help??
Also, lately there seems to be a squeaking noise coming from somewhere, when I put the car in park, get out, and inspect the engine, no noise. But when you drive, you hear it?? I was thinking either a wheel bearing or a U-joint?? What could be hurt from so little use(although I do get on it to test out new parts and such, but not badly..)??
Old 04-06-2004, 06:15 PM
Danny2tek's Avatar
That's the pump for the AIR system when the engine is cold it pumps "AIR" into the exhaust to help warm up your cats faster.
Old 04-06-2004, 06:21 PM
wbw2's Avatar
Is it supposed to be relatively loud??
Old 04-06-2004, 06:27 PM
Danny2tek's Avatar
lets just say it's noticeable the pump is located in front of the drivers side wheel
Old 04-06-2004, 06:35 PM
wbw2's Avatar
yes thank you, I think that is it, what do you think about that other squeak?
Old 04-06-2004, 06:38 PM
Danny2tek's Avatar
maybe a bushing..... do you hear it more when you go over a speed bump?
Old 04-06-2004, 06:40 PM
wbw2's Avatar
NO, just sort of random, but definitley there!!
Old 04-06-2004, 06:42 PM
wbw2's Avatar
I should mention, the squeak does sound rotational..
Old 04-06-2004, 06:48 PM
Danny2tek's Avatar
I say lift the rear put it in gear and try to listen for it
Old 04-06-2004, 06:50 PM
wbw2's Avatar
THANX.!!
Old 04-06-2004, 06:55 PM
Danny2tek's Avatar
good luck
Old 04-06-2004, 07:59 PM
Copy & Paste Moderator
VIP1's Avatar
To my knowledge, that system is only on 2001 and 2002 models. The 1998 F-Body did not have an AIR system.
--VIP1
Old 04-06-2004, 08:44 PM
ddelallata's Avatar
--VIP1
All LS1 f-bods have it.. the only difference on the newer LS1s is that they have a hose that gets fresh air from the factory air cleaner while the 98-99s don't.
Old 04-06-2004, 08:45 PM
ddelallata's Avatar
about the squeaky noise......make sure your spare tire is fully secured. Get back there and turn the butterfly to make sure it's on there right.
Old 04-06-2004, 08:50 PM
cyphur's Avatar
VIP1, its my personal experience that '98s DO have the AIR as well as the EGR provisions. I had a '98 formula ws6, and it definitely had the AIR system. Couldn't miss the whirring when you started her up. If its an f-body LS1, and in stock trim, you've got the AIR system.
Old 04-06-2004, 09:42 PM
Danny2tek's Avatar
Old 04-06-2004, 10:49 PM
VIP1's Avatar
I guess I was wrong.
--VIP1
