please check my math...
I have a 2002 SS with a 3.42 rear.
I noticed that according to the speedo, first gear can reach almost 50mph.
This didn't seem right until I tried to calculate.
I picked up 2.66:1 for first gear from a couple of websites.
tire size = 275/40/R17
sidewall 275 * .40 = 110mm
total diameter ((110 * 2) / 25.4)+17 = 25.6614in
circum 25.6614 * pi = 80.5767in
in Miles 80.5767 / 63360 = 0.0012717miles
First gear 2.66?
5800 / 2.66 = 2180.4511rpm
2180.4511 / 3.42 = 637.5588rpm
637.5588 * 60 = 38253.5285rpHour
Estimated speed
38253.5285rpH * 0.0012717miles = 48.647mph...
I thought the speedo was lying or something. Do you guys see the same in you cars?
I can't imagine what would happen if there was a higher gear out back.
Is there any transmission mods to "spread" the close ratio's out a bit? Because this seems excessive to me.
I'd like to improve acceleration without sacrificing the top end.
First gear 2.66?
Estimated speed
I'm not really sure what you're complaining about here though. Are you saying 48mph is too much or too little for 1st gear? Higher gears will decrease the top speed in each gear. A 3.73 or 4.10 gear would drop that top speed down even farther, forcing you to shift sooner. I can already easily spin the tires in 1st gear.
**Edit**
And the rev limiter is actually at 6200RPM (our tach is pretty slow, and can't keep up with the engine revs in 1st and 2nd gear very well). So top speed in first gear is more like 52mph. Check out this site for all the details you need on gearing vs mph...
http://www.f-body.org/gears/
I'm kinda complaining that first gear is too high. I don't want to swap out the 3.42's in the rear. I want to swap out the 2.66 first gear and 1.78 second gear in the transmission for something lower say 3.00 for first and 2.1-2.25 for second. This would provide the better acceleration in the lower gears and keep the nice cruising gears up top. This wider setup is something I see on foreign cars more often since they usually have smaller motors and lack the low end torque. Muscle cars have always had that close ratio style trans.
The question really is: Is there any place I can find aftermarket gears for the T56. I've been searching the sponsers and other websites, but I can't find any. Thought you all might know some "inside" info.
BTW. Thanks for the link to the speed/gear calc. Beats having to figure it out on my own.
Ok, I was looking in the wrong place. Apparently Cadillac already thought of it. From the CTS-V: Tremec T56 :
1st - 2.98:1
2nd - 2.07:1
3rd - 1.43:1
4th - 1.00:1
5th - 0.86:1
6th - 0.56:1
final 3.73:1.
So anyone know if this trans would cause any headaches going into an F-body? Or anything at all about this trans?
1st - 2.98:1
2nd - 2.07:1
3rd - 1.43:1
4th - 1.00:1
5th - 0.86:1
6th - 0.56:1
final 3.73:1.
Copy & Paste Moderator
1st - 2.98:1
2nd - 2.07:1
3rd - 1.43:1
4th - 1.00:1
5th - 0.86:1
6th - 0.56:1
final 3.73:1.
1st - 2.98:1
2nd - 2.07:1
3rd - 1.43:1
4th - 1.00:1
5th - 0.86:1
6th - 0.56:1
final 3.73:1.
--VIP1
All i gotta say if you do change the gears get some slicks... even a stock car puts up a pretty good smoke show with little effort and changing that gear will only make it easier for those tires to break loose
Like I said, I can light the tires up easily in first, and my engine is still mostly stock. Lower gearing isn't going to allow me to accelerate any better in 1st, it's only going to allow me to light 'em up easier. The gear reduction is only going to come into play in the higher gears. And top end, how fast do you really want to go anyways?
And the CTS-V gearing isn't a Cadillac thing. That's the gearing the Z06 uses, and if you compare closely, you'll notice the ONLY gear that matches is the 1.00 fourth gear. All the other gears are difference, as is the rear ratio. If you want gearing similar to the Z06/CTS-V overall, just put 4.10s in the rear. If you want the benefit of the different gears in the tranny alone, put 3.73s in the rear. Swapping that tranny into your car is a lot more effort and isn't going to be any effective difference than just slapping a new rear gear in.
Originally Posted by VIP1
Last I heard, thats the same transmisson in the F-body. Maybe they changed first?
No. Typically, muscle cars have had gear boxes with wider spacing of the ratios becuase the power they made was sufficient to deal with it and there were fewer gears available. (3sp and 4sp were the norm) A close ratio gear box has the gears spaced numerically closer together to keep the engine reving higher during acceleration. (There is less of a RPM drop between gears.) Smaller/less-powerful engines need closer ratios because they would stuggle with a wider spacing when the RPMs dropped.
--VIP1
--VIP1
I had 4.10's in my old car and hated them. They work on the strip, but suck for road racing. I guess I should have mentioned that I was looking to race road courses with this car instead of just 1/4 tracks. That changes the entire dynamic of how you want to gear a car.
Originally Posted by Ackattack1
what kinda top end do you want? I think even with 4.10s in 5th gear, the top speed is about 150.
I love the site. You guys are very helpful. Much thanks!!
I disagree. Muscle cars tend to have big low-end torque and narrower powerbands than higher revving smaller engines. That narrow flat torque is best served with a close ratio box that keeps the rpm's in that tight powerband. Compare that to something like a '03 BMW M3 that has a 4.23:1 first gear, 2.53:1 second gear and 3.62:1 final. That's how they get that 3000lb car ( with no torque ) moving from a standstill.
The gearing in German transmissions is numerically higher becuase the rear gear is numerically lower. American transmissions use numerically lower gearing in the transmission and a numerically higher rear gear ratio. German transmissions also tend to have a 1.0:1 as the final ratio in the transmission while american transmissions have an overdrive ratio as the final gear. Mathematically (final ratio X rear gear) it is almost the same. German transmissions are made this way though, to improve high-end acceleration for the Autobahn.
--VIP1
The early LT1's came with 2.97 and 3.36 first gears. The Z06's come with the 2.97 also.
There is probably a vendor that can sell the gears, but you might have to buy more than you actually need.
Actually, those are the same gears available in a Z06. If you want the widest ratios available, get a T56 out of a 93 LT1 6 speed with 2.73 rear end gears:
1 2 3 4 5 6
3.36 2.07 1.35 1 .8 .62 (a 2.97 first gear came with 3.23 rear end gears)
Compared to the transmission in the 94-02 f-bodies:
2.66 1.78 1.30 1.00 0.74 0.50
Z06:
2.97 2.07 1.43 1.00 0.84 0.56
If I had my choice, I'd take the Z06 gearing 1-4 with the .74/.5 overdrives.
I think the Z06 has the low first gear to make up for the low torque of the Z06 cam (everything is relative though )
1 2 3 4 5 6
Z06:
The time it takes to post here you could have found vendors such as D&D Performance, Forte's and Rockland Standard Gear that can hadle such things.
Also, the time it took to type this was longer than the time it took to find out that the new GTO has 2.97, 2.07, 1.43, 1.00, .85, .54 in a T56 behind a LS1 in the conventional location.
why not get something like a richmond 6 speed instead of fusing with the z06 tranny. It has a few options on gearing, 5th gear is 1:1 and 6th is OD.
Muscle cars do have a lot of low end torque, but they also have a broad power band (not a narrow one). Just look their dyno graphs and compare them to newer/smaller engines. You'll notice that the muscle car engines have a broader/flatter power band and the smaller engines are more "peaky".
--VIP1
--VIP1
I was trying to make note of the larger difference between first and second in the getrag... 4.23 in first and 2.54 in second. I'm almost certain that 6th gear in the M3 is an overdrive while 5th is 1:1.
I think we do agree, but just focus on different aspects of the topic. What you mentioned is what I was looking for. Good acceleration at all speeds.
Gotta get out of those turns!!
