spark plugs
spark plugs
I need help l would like to change my plugs stock plugs #PTJ16R15. But I see guy running NGK T55. Will they work in my ls1. It is not stock. Cam, fast 92mm intake long tub header ported heads, m6, 4.11 gears. An l would like to change the thermostat to a 160d. It overheated in stop an go in the city yesterday. Should l also change the oil in it too.
LS1Tech Administrator
Received 1,795 Likes
A 160° t-stat isn't going to stop you from overheating. The only way that changing the t-stat will help with this is if your current t-stat is not opening properly/fully. All that a lower temp t-stat will do is reduce the minimum post-warm up coolant temp. Maximum temp will still be determined by cooling system capacity/ability and weather conditions. Also, without fan reprogramming, a lower temp t-stat won't change anything at all in stop-and-go traffic, it would only lower the minimum coolant temp at higher speeds.
I started to put in ngk-t55 with a gap of .50. Now l they too put the last three in on the heater box side they look like they are going to suck, with header. Still looking at why it over heated.l look at fan an got new relay an found out the where in backwards.not sure if that was it. Thank for all the help. The car going to get retune next weekend dieing to find more hp, if they can.
Very back plug on passenger side you can get to easier under neath the car. You can remove coil packs to it makes it easier.Still a pain. I dont have no emission stuff on my car so it makes it so much easier.
Just change my plugs it tock 1.5 hours. The hardes plug was#6. I got my plugs ngk tr5 at autozone for $3 each. Should have my new coil tomorrow. Or check ws6 theybw
Have great deals
Have great deals
Anyone ever try E3's? I put in a set in my wife's corolla. Not a v8 I know, but I could tell a difference from densos that were in there. I almost got a set yesterday, but backed out. I wanted to find d out if anyone has tried them 1st?
Was trying to get a set for my VRod but they didn't make them. CEO called me wanted to know if they got plugs made for my bike would I try them. Of course I said yes. But nothing came of it.
If your car still has the original factory radiator in it that may be your problem. 14 years is a long time for a radiator to continue to function properly. I would just go ahead and purchase a new one. You can buy them for around $100. I bought one a year ago when my 2000 Z28 started to run warmer than usual. That solved the problem for me. A 160 degree thermo will not cure problem.
The stock radiator in my '98 is still perfectly fine at 15 years old now, but it's a low mileage example. On the other hand, the stock radiator in one of my Firebirds failed when it was only about 9 years old. So age alone isn't always an indicator.
14 years by itself is not necessarily a problem, it's more about how much usage it's seen, how well maintained the cooling system has been (regular coolant changes, etc.), and the external condition of the core (damaged/clogged fins, etc.)
Without knowing the overall condition of the OP's cooling system, vehicle mileage and maintenance, and what parts may have already been replaced or tested, it's hard to single out one part as the most likely reason for overheating. In your case, replacing the radiator obviously helped, but age alone is not necessarily an indicator of radiator failure in all cases.
I just hate to throw parts at a car without comprehensive testing of the condition. All that the OP mentioned was "overheating in stop and go traffic", and then he mentioned replacing a fan relay. No further updates were mentioned.
That's great, but my 15 year old stock radiator is still working just fine.
I always been told that spark plugs are spark plugs they all do the same thing. The spark always jumps to the nearest contact point I just use acdelco I don't see any difference
