Putting my T/A up for the winter
I live in MI and in the winter I'm planning on once a month starting it, let it run until it gets to operating temp the shut it off. Or pull the battery put in fuel add. and let it sit. What best for my car ? Thanks
LS1Tech Administrator
Received 1,492 Likes
Add stabil to a full tank of gas, running the engine for long enough to let it seep into the system, and then shut it down till spring. No need to start it at all during winter storage, better to leave it sit.
No need to pull the battery either, if you have a smart charger or tender. Or just pull it if you prefer.
If you have premium gas without ethanol available then switch to that if you don't already use it, you'll want to run 2 or 3 tanks through it and then fill it up before parking it. Heck if you can't get premium with out ethanol I'd run to down to less than a 1/4 tank and fill it with 87 octane. What I'm getting at here is that ethanol doesn't store well at all. I never buy gas with it in it at all if it can in anyway be avoided, and for the last 5 years with my Monte Carlo and 3 years with my Trans Am I haven't even bothered with putting any fuel stabilizer in the tank and both cars start right up and run just as good as when I parked then. Also on a side note my local small engine and boat motor mechanic hate's Sta-bil and prefers using Sea Foam as a fuel stabilizer. As far as the battery goes go to Wal-Mart and buy a $15 trickle charger if you don't already own a full size smart charger, I switch mine from car to car every month during then winter.
I've been storing cars for the winter for about two decades now, always with E10 fuel and always with a full tank. It's good that you haven't seen any issues with your method, but I've seen no issues with my method either.
No idea what his complaint is. I've been using Stabil brand for about 20 years now, in everything from carb'ed cars to SEFI cars to snow blowers and hedge trimmers. It's been great. Every time I open the Holley on my Nova, it's super clean on the inside, even after several years. In fact, most of my power yard equipment is between 12-16 years old without ever needing a carb rebuild - so I don't see any issues with Stabil. Just my personal experience.
Not to hijack the thread, but I had another question about putting these cars in storage; I wonder if I would be better to leave the T-Tops off when the car would sit for an extended period of time? Just so the gaskets don't stay crushed to long. Reason I say this is because the lady who owned the car before me always kept the T-Tops off (kept it in a garage) and gaskets are in perfect condition (14 year old car).
I would leave the t-tops on.. The gaskets on my car seal just fine, and they havent been stored off. I would rather have too replace a gasket than have the interior open and be full of garage dust in the spring..
I purposely keep the interior as sealed up as possibile, and then use a tub of Damp-rid in the center console cup holder to keep interior mositure build-up under control. I do this all year, not just for winter storage.
Stabil, full take of gas, up on jackstands is the way I store mine, I do however have the jackstands in a way so the weight of the vehicle is on the suspension, its not good for the shocks or struts to leave them unsprung for a extended period of time. I pull the battery, through the cover over it and let it sit until spring.
I don't even bother with jack stands, I just air the tires up to their max rated psi and park them on carpet. Never experienced any permanent flat spotting on regular steel belted/Z-rated street tires over short term winter storage. If you are storing the car on some sort of soft/bias ply/competition tire though, this would be a greater concern.
haha, this will be my first DFW winter so I am wondering what kind it is, im from chicago but ive been stationed out in Virginia Beach for the past 4 years
and as far as ethonal being "bad" it absorbes/mixes with moisture in the tank, unlike gasoline where you can see it floating on top of the gas and when you get to enough moisture it causes problems ie corrosion and watered down fuel isnt good for combustion, im pretty sure thats what the problem is with ethanol.
and stabil slows the "decay" of gas by acting as an anti oxident.
if youre worried about the tire flat spots they make those rounded platforms for each wheel (i think theyre priced too high)
i say just throw some stabil in the tank regardless what mixture of your gas and store it
Sorry for the thread jack but I didn't want to start another thread. My oil has ~1000 miles on it. So should I change it before I store my car or change it first thing in the spring?
