Car seems to have less balls....
Car seems to have less *****....
Checked for a vacuum leak with some carb spray so I think I can rule that out, this happened around the time I changed my oil and I used Royal Purple 5w-30 the car previously had 10w-30. My friends said its a possiblity of the clutch going but its not slipping hard just higher rpms and not having the power it did a week or so ago when I step on it. It had a oil leak when I got which we believe is the rear main seal. Before I go and spend $1300 on putting in new clutch,flywheel,slave,etc what are my other possible faults causing this? My thoughts injectors?maybe ignition? This is my first manual car and I'm on a budget for the time being....the Navy doesn't always pay well LOL.
how many miles on the motor ?the slippery clutch sound most likely .a ignition problem would show a code .throw some concentrated injector cleaner in the tank,to clean out the injectors .maybe the cats are clogged .
Got a quote for $1250, clutch,flywheel,slave, & rear main seal. By CCCMotorsports nearby San Diego. I'm going LS7 set up, not doing anything crazy til maybe next year just general maintenance and some bolt ons.
