New to LS engines and have some questions.
So I have been working on a procharger build for my lexus gs400. Iv been told swapping a LS engine in my car would be alot cheaper then building my current 1uz. Anyways I went to a drift event and and there was a 240sx with an engine swap and it make the most beautiful sound i have ever heard... I found his car on a site and it was indeed an ls1 engine and I am all for the swap and want to start the build ASAP. My questions are, the SOUND and WHP are what I'm after. The LS1's mods were lingenfelter heads, ls6 intake manifold and custom ground cam. Would I need to replicate these engine parts to get the same sound? Or can I throw on my current V2 vortech and basically replicate the same exhaust/piping mods while making around the same whp?
Anyways what is the most price effective way to build this engine? Do I go to a junkyard and find a block and just build it up in my garage? 380 to 400whp is what I'm looking for. Since the car is my DD
here is the site of the car where I got my info
http://streetsweepergang.com/paint-drippin-elite-automotive-candied-240sx/
http://m.youtube.com/watch?v=WggMq_JzWyc
And a video of the car and the exhaust note I am trying to achieve
Welcome...
Your goal of 380-400 hp is easy to do with a junk yard LS1/6. Cam, intake, and headers is all you would need. Heads would take you past the 400 mark.
Is this car going to be a manual transmission ?
As far as sound goes, do you have room in the car for long tube headers and a true dual exhaust ?
Welcome...
And I was actually thinking of using a auto since the car is my daily.. I wanted to use the manuel mode on the transmission and hook it up to my steering wheel shifters.
And as for the headers I'm not exactly sure if it will fit.. I know I have room to run true duels but I'm sure with enough cutting I could fit some long tubes, does it sound like the 240 has long tubes?
what is your budget ? a ls1,ls6,ls2 ,and some 5.3s use a aluminum block .the 5.3 will probably be the easiest to find .look at places like Texas Speed to get a idea of how much things mite cost.get a cam meant for a super charger ,it is worth the extra power .buy the cam last after you have bought all your parts .
And yes I was talking about pro charging the ls1 with the vortech
Procharger is a brand of superchargers... http://www.procharger.com/
Vortech is also a brand of superchargers...
http://www.vortechsuperchargers.com/
Both are superchargers, which are belt dirven turbines.
What supercharger are you thinking of for your LS build ?
Scroll down to the Conversions and Hybrids section and do a little digging, you should be able to find at least a couple of build threads with cars similar to yours. We can't really help much with helping plan a engine build without a budget to work within, but you may be better off selling the supercharger and going NA depending on cost of brackets and piping.
So there are many ways to skin this cat you just have to know what your ultimate goal is and what you are willing to spend...as other members are asking. Think about things such as staying NA vs Forced Induction....two totally different ways to attack your build.
As far as the sound, that will depend on a few factors like exhaust configuration, cam, is it FI or not, etc.
I'm confused here ^^^
Okay, we'll actually I was the one confused.. I thought belt driven turbines were prochargers. I thought supercharger ss were the ones that sit directly on top of the engine. So yes, I have a vortech supercharger head unit that I was planning to install.. On my gs. I was thinking if I do the engine swap I would just use the vortech to make power and not have to spend too much for n/a power
Also your hp goal should be extremely easy to achieve, 400rwhp is child's play N/A or FI. The guy in the 240sx you linked to must have a very very mild cam if he is only making 380rwhp with LPE heads...
Size?
Centrifugal type superchargers are the ones that look like belt driven turbochargers, Roots type superchargers are the ones that sit on top of the engine.
I don't really have a budget. I have 1500$ to build an engine and I was going to pull out a loan for the rest. I was hoping I could build an ls1 from scratch and just boost it with the safest tune possible. Maybe throw some headers and a custom exhaust. I have not built an engine before but I'm on vacation and I was thinking this would be a perfect time to start
Hate to bust your bubble but your not going to build a LS1 from scratch for $1500. I think your first step is going to be to find a bracket to hang that SC off a LS motor, I did a quick search and found that Vortech has discontinued many of there there LS based kits so it might be hard to find something to fit. It may end up costing more than its worth if you have to have an expensive custom bracket made.
Idk. I got it on craigslist on trade. I will have to look for it and find out.
If you can figure out if that SC is big enough and how to get it to work, just about any LS motor will work, I'd just look for a good low mile motor. A 5.3 L33 would be my top choice, it's a truck motor so it's cheaper but it still has a aluminum block plus it has 799 heads (same as LS2 and LS6 motors). Run it at 8lbs of boost should be reliable with a good tune and good for at least 425-450rwhp.
