rear end still not getting it
Gonna be in the market for a WS6 soon and dont really understand the whole 12 bolt 9in rear end lingo.
I read the 'so you wanna go fast' thread
I will be getting an M6. Basically if i want to mod the car I need to spend $2500 on a new 12 bolt rear.
Why would I not just get the 3.73 gear in it to take some of the stress from the low end torque out of the car?
Can I have a 12 bolt rear end and put the gears in it? Would that really be needed?
My goal is to have a nice streetable ws6. full bolt ons with supporting mods. I would like to make it heads cam ready in case i wanna go that route in the future
It really depends on how you want to use the car. The 10 bolt seems to hold on pretty well in the autos even with decent power. The 6 speeds seem to be hit and miss but if you aren't doing 4-5000 RPM clutch dumps I would let the 10 bolt easy until it gives up the ghost. On my last build I knew I was gonna beat the **** out of it so I went ahead and bought an S60. My full bolt on stalled auto before that I just ran the 10 bolt. Never had an issue.
Put gears in a 10 bolt? There are really to 2 trains of thought on that. One is that the 10 bolt is junk and you shouldn't spend any money on. Ride it till it breaks then replace. The second is that the 10 bolt isn't complete junk and if you know what your doing you can make it last.
I'll say this...there are plenty of guys on this forum running pretty fast times and putting down decent power on the 10 bolt. It has its merit. While not strong it is extremely efficient and reasonably light. There are also guys who have destroyed them in a stock car. It's truly a roll of the dice. In my experience they aren't made out of glass. I would say use it until/if it breaks and then switch if you want. If you want gears go for it.
ok cool that makes more sense.
My last question would be if I decide to get 3.73 gears (or a different one) and I keep the stock 10 bolt and happen to break it is the first thing that breaks the gears?
Then I just wasted money on the gears
Or is it another roll of the dice thing?
10 bolts are found in smaller GM cars and trucks (like the S10)
12 bolts are found in larger GM trucks like the Silverado
and the 9" is a Ford design rear end found in their mustangs and trucks.
JD,
Correct me if I'm wrong but my understanding is that the shock generally flexes the housing and causes the ring gear to walk up the pinion gear.
I do agree that the weakness of the 10 bolt is over exaggerated. I have broken them but it was on DRs and a hella lot of abuse. As I stated, my stalled auto bolt on car never hurt it. No noise, no whine, no nothing and I was pretty hard on that car. I just kept it properly maintained.
