? about 0W-40 Mobil
? about 0W-40 Mobil
Okay after reading the post on the best oil, i decided to buy some Mobil
0W-40 European Car formula SuperSyn. Did i make the right decision? I am using Mobil 10W-30 right now.
It gets very hot in Texas! And i drive my car the way its supose to be driven. I won't be puting it in for two days, so i can still retern it if ya'll think i should get the 30 instead.
02 camaro Z28 hp 384.1 tq 372.3
Engine Mods
MTI Tune
ppc headers Y-pipe
RT cats
Z06 cam
ASP pulley kit
SLP MAF
LID
BBK throttle body
fast toys ramair
becool radiator
160*
MAgnaflow
Engine Mods
MTI Tune
ppc headers Y-pipe
RT cats
Z06 cam
ASP pulley kit
SLP MAF
LID
BBK throttle body
fast toys ramair
becool radiator
160*
MAgnaflow
Well Im running with no problem here in Chicago. Its not as hot as Texas though, but on hot days here running the car hard Ive always sustained great oil pressure. If anything Im sure Patman will chime in hes the oil expert here. As far as my opinion I dont think youll have any problems, if Im not mistakening Mobil 0w40 is like a heavy 30 when heated or something like that. Good Luck
My next oil change gonna run the 0w40 since advance here by the house has it now
Mobil 1 0w40 is definitely a good choice, and is a much better viscosity for the LS1 than Mobil 1's 5w30 or 10w30, both of which are closer to being 20 weight oils.
(Patman) lastnight i was reading up on some of your posts from another website, and you recomended german Castrol 0W-30, or amsoil 0W-30, more so than the mobil one because of the higher iron content in the mobil one which might mean more engine wear than the other two, but still find that it is a dam good oil. So if i can find one of those easly enough ill retern the mobil one. And man you are sure deadicated to answering all the oil questions you get asked, ive learned alot from your posts. thanks!!
Originally Posted by 1BADFNZ
What's your thoughts on K&N oil filters?? I had someone tell me that they suck and to run wix.
Your thoughts??
Your thoughts??
However, if Patman has more current info on the K&N oil filters than I have, I defer to the expert.
Your thoughts??
Your thoughts??
Wix makes good oil filters too, but they don't flow quite as well as the K&N. I ran a Wix on my LT1 just before the K&N. The Wix would be a great choice for a daily driver that isn't driven super hard.
hey patman, i told my brother to use the german castrol Ow-30 also, he has a 2003 chevy SS truck, 6.0L. is this okay?
on another note i found the Castrol really easy today at one of our autozone's, and put it in today. I'll be returning the Molbil.
whats the part # for the k&n oil filter? thanks ahead of time.
The German Castrol will work well in the 6.0 engine too, in fact it'll work well in any vehicle which originally calls for 5w30 or 10w30.
The K&N oil filter number is HP1007 for the stock one or HP2006 for the longer one.
Originally Posted by pewterta
can i use castrol german in my ls1 ...i live iin chicago..and how often should i change tthe filter???
thanks!
thanks!
You can definitely use GC 0w30 in Chicago. Your weather is like mine in Toronto, and I use it year round in all of my family's cars.
Originally Posted by JL ws-6
Well filters are being discussed... how does the off the shelf fram stack up?
Originally Posted by Patman
Fram oil filters are to be avoided at all costs. I like K&N oil filters myself, but also recommend the Wix, NAPA Gold, Carquest premium, Purolator Plus, Amsoil, STP or Walmart Supertech filter (which is the same as STP)
