How to out run a Z06
Old 06-20-2004, 04:40 AM
TWINK's Avatar
Default How to out run a Z06
What kind of mod's would u have to have to out run a 405hp Z06 ?
With a auto Z28 ?
Old 06-20-2004, 04:50 AM
1BADFNZ's Avatar
Nawzzzzzzzzzzzzzzzz a big bottle..... no make that two of them
Seriously though a 100 shot of Nitrous should take care of that pesky problem
Old 06-20-2004, 09:40 AM
Administrator
unit213's Avatar
A stall converter, tires, and nitrous will do the trick. If you don't want to go the nitrous route, you're going to need all the bolt-ons.
Administrator
unit213's Avatar
Not necessarily. I sprayed a 100shot and it only put me a 12.2 @ 117mph. That's still within stock Z06 range.
Old 06-20-2004, 12:08 PM
TWINK's Avatar
Ive got a stall cam and all the bolton's, i did out run one but no one belevied me that i did w just a hot cam and no tune
Old 06-20-2004, 01:05 PM
ULTIMATEORANGESS's Avatar
NA youll need every bolt on.since youre an a4 a big stall will help tremendously.
running them from a roll is a different story.
Old 06-20-2004, 07:23 PM
warmadness's Avatar
find a zo6 with a bad driver ,a really bad driver
Old 06-20-2004, 07:38 PM
Moderator
davered00ss's Avatar
Stock they run 11's in the 1/4. Slowhawk ran 12.3 in a stock 2003 C5 M6.
Old 06-20-2004, 08:35 PM
Strahley's Avatar
With an automatic, your best bet would be from a dig with most, if not all, bolt ons, sticky tires, and a big stall
I edged one out at the track one day, and I have most bolt ons, a cam, and some drag radials, M6. So no you don't NEED juice to do it, but that would insure it...unless he's got his own secrets
Old 06-20-2004, 08:36 PM
SJLingenfelter's Avatar
Thats what i was gonna say.
Old 06-20-2004, 08:45 PM
Administrator
unit213's Avatar
I'd have to see that to believe it.
Old 06-20-2004, 09:05 PM
NKAWTG...N
StoleIt's Avatar
12.3 in a stock C5? I can't believe that...that just like a jump my mind wont make.
Old 06-21-2004, 12:07 AM
Strahley's Avatar
If the '03 was a Z06 I would beleive it. I don't beleive that a bone stock C5 will run 12.3
Old 06-21-2004, 08:18 AM
crainholio's Avatar
Wow...a "stall cam"...that's a new one. Got your torque converter changed to a tighter LSA too?
Old 06-21-2004, 08:35 AM
Derek98z's Avatar
Wow. Stock Z06's run mid 12's around here.
Old 06-21-2004, 10:01 AM
CamaroSS's Avatar
Headers, Exhaust, Lid, 3500-3800 stall, Lower Control arms, tune, and with a Hot Cam, you should be looking at high 11s. Get a nice set of heads, subframe connectors, torque arm, and a rear sway bar, and your at the low low 11s. Maybe high 10s, if now then spray. Also, a set of nice and sticky tires is needed, and the added insurence of a stronger rear end might be in need, otherwise good luck. They are not that hard to beat.
Old 06-21-2004, 10:06 AM
RaNsOm's Avatar
Old 06-21-2004, 10:08 AM
technical's Avatar
Line up, have your girfriend (or pay some chick) to flash her **** at the driver then take off.
Hopefully the driver is a guy or at least a girl who is impressed with big ****.
You should take 'em buy a car or two.
Old 06-21-2004, 11:08 AM
Administrator
unit213's Avatar
"Ya, it's got a 3500 stall cam and a 224/224 converter on a 114LSA."
Old 06-21-2004, 03:35 PM
16nrollininaws6's Avatar
Raisin' the flag.... No way a stock C5 got there. Also, you make it seem like all Z06's run 11's. Few can reach that stock, it takes a great driver, a perfect run, and a strong car.
