LS Identification and Swap
Hey Everyone, we are a high school auto shop and are trying to figure out exactly what we have before we proceed with a project.
It is a 6.0 liter, aluminum block, has the higher intake, has a cam sensor in the front cover and cathedral style intake ports. We have looked into some different configurations on line and can't figure out if we have a truck engine (pretty sure they are iron blocks?) or something else? Any help to get us started would be appreciated!
We are new to this LS game but are really looking forward to getting into it!
Thanks!
Thanks!
It's stamped on the back of the block, what kind of intake? If it's the truck intake its a trailblazer SS. Good find! Should have 243-799 heads or like the one I bought one of each!
DoD cover will have veins in it.
http://www.nathanbittinger.com/fiero...4/DCP03238.jpg
DoD cover is on the left.
Yes, it definitely has that cover with the veins on it.
Restricted User
If it is indeed an aluminum 6.0 with cathedral ports and DoD, then it is an LFA. If it also has VVT, it is an LZ1. They were both hybrid engines. Basically, displacement on demand hybrid versions of the LS2.
Delete the DoD and you basically have a TBSS LS2.
But this is the same guy that is new and is asking us to help him I.D. it...
Without casting numbers or pictures of said engine it's pure speculation.
12568952 Is likely the casting number of the Aluminum 6.0 block
We would need the head casting numbers to go from there.
Restricted User
Remove the heads, replace the lifters with standard LS7 lifters, and then replace the valley cover with a non-DoD valley cover.
At that point, you have an LS2 from a TBSS.
Thanks Joe! What would be the benefit of doing the cover and lifters swap over leaving it the way it is?
Thanks again for your help!
Can I ask you now what you would recommend as a set up for this? Basically 1) what transmission?
2) would it be cheaper to put a carb and intake on it or run a stand alone type computer system?
Thanks again Joe for all of your help and direction!!
Hey again Folks. Is there a recommended way to run these engines? Basically is there a choice of control system we can buy to run it or is a carb and intake a better choice? I have looked around for a donor vehicle but haven't had much luck. Has there been any success with an aftermarket computer and harness system?
Also what transmission is a good choice to bolt up to it?
Thanks again!
Thanks again!
