wtf is a "four bolt main" (and other lingo)
Old 07-06-2004, 01:26 AM
Stone0fFire's Avatar
Default wtf is a "four bolt main" (and other lingo)
hey this old guy is talking about double pumper this and that
and if i have a two bolt or four bolt main
and a six pack?
and something about getting a mallory ignition?
anyone know wtf he is talking about?
Old 07-06-2004, 01:32 AM
Just Floor It's Avatar
Double Pumper has to do with a Carbureator(SP?)
Two bolt main and four bolt mains, errrrr.....I cant think of the CORRECT term
A six pack is a carb setup, it uses an intake manifold that has space for 3 2 barrel carbs...You put the 3 2 barrels on, and its called a "six pack".....Ive also heard it called a six barrel carb
Mallory is just an aftermarket ignition company
Hope this helps
Old 07-06-2004, 01:46 AM
BTW: I hope he wasent asking if ur car has this stuff....
Old 07-06-2004, 01:51 AM
brutusbeast's Avatar
Default lol... Can't think of it??
Two bolt or four bolt mains refer to the number of bolts holding the crankshaft in place. They bolt onto the main caps and hold the crank snug. We have six bolt mains. Three on each side. Mallory is also known as MSD. Pretty close on the carbs. Three deuces is three two barrel carbs. A four barrel carb has four holes into which air and fuel mix. A two barrel has two barrels. The reason for three deuces is fuel economy when driving regular, but plenty of gas when you floor it.
Old 07-06-2004, 01:55 AM
Restricted User
NOSjohn's Avatar
Damn, there are some young whipper snappers on this board...
Old 07-06-2004, 01:59 AM
Old 07-06-2004, 02:01 AM
BigBronco's Avatar
two bolt, and four bolt mains is relating to the main caps that hold your crank in your motor in place. the number of bolts per crank is what gives the number.
6.0 blocks have 6 bolt mains. 4 on the tops of the caps and one on each side of the caps
6 pack is like what was stated....
an intake set up when using three pairs of 2 barrel Carbs
Mallory is an ignition and spark company
Double pumper is a term they use for a series of carbs holley had... the famous Double Pumpers
Old 07-06-2004, 02:13 AM
chpmnsws6's Avatar
hey now!
Old 07-06-2004, 02:35 AM
Nesto's Avatar
all i know is my car is fast !!! lol ;-)
j/k you shoulda told him its fuel injected (like every other car in the last 20+ years... i'm 24 =P), or just popped open the hood. that would've stopped most of the questions. =)
Old 07-06-2004, 06:46 AM
technical's Avatar
Carburetor: Double pumper == two accelerator pumps instead of one.
Most notible buzz word/phrase...Holley double pumper.
Old 07-06-2004, 08:04 AM
Administrator
unit213's Avatar
There are som old bastards too.
Old 07-06-2004, 08:54 AM
Moderator
jimmyblue's Avatar
Double pumper is a 4-barrel carb with mechanical
secondaries; a vacuum-secondary carb does not
need the second accelerator pump. "Double
pumper" is easier to say than "mechanical
secondaries" and people who wear camouflage
trucker hats will understand you better.
"Twice as old as I used to be and three times
the bastard"
