98-99 setup vs 01
Old 08-03-2004, 08:26 PM
af_187's Avatar
Default 98-99 setup vs 01
Read JRPs sig in and out, maybe I did miss it but I dont wanna hear him bitch
are 98-99 setups usable on my 01? If so..what kinda moddin do i have to do
Old 08-03-2004, 09:03 PM
af_187's Avatar
damnit..someone help
Old 08-03-2004, 09:09 PM
procharged's Avatar
what do you mean by setups? interchangable parts?
Old 08-03-2004, 09:15 PM
af_187's Avatar
holy **** i forgot to post half my post lol. Sorry guys. I ment the headers and ypipes. I wanted to know if i can use 98-99 header/ypipe rigs on my 01. Sorry
Old 08-03-2004, 09:21 PM
ddelallata's Avatar
You can use the Y-pipe, but the Emissions legal headers for the 98-00 have provisions for AIR and EGR. 01-02 headers only heve AIR. Bolt patterns are the same though. Try to buy application specific parts to avoid problems with AIR flanges not lining up. Or you can buy the race ready headers which don't have AIR or EGR.
Old 08-03-2004, 10:27 PM
af_187's Avatar
so the MAC systems for the 98-99 wont fit
Old 08-03-2004, 10:30 PM
ddelallata's Avatar
they will fit , but you'll need to get a plate to block off the EGR. I'm not sure if the AIR will line up either. You could just block them off and have the codes deleted. They will bolt up to the 01-02 LS1 head though. The Y should fit also.
Old 08-03-2004, 10:54 PM
af_187's Avatar
doh, too much work I am thinking about getting edelbrock headers, the uncoated ones, becuz im going to be living WAY down south...maybe this would be a better route then my buds used ones
late next summer/fall i think i goto kook or QTP anyways
af_187's Avatar
so yeah thats my next ?...are uncoated headers that bad ? or should I just get the uhm..the MAC setup..I take it they come coated
Old 08-03-2004, 10:59 PM
jrp
SN95 Director
jrp's Avatar
straight from the guide
7) If you want to swap 98-99 and 00-02 headers around you'll need to remove your Air system or purchases the Air tubes from the year the headers were made for since the 98-99 and 00-02 have different Air tube setup.
8) It should go without saying but if you want to swap 01-02 headers on your 98-00 you'll need to remove you EGR system.
9) 00 are an oddball year as the EGR and Air setups are different then the 98-99.
10) When removing the Air system on the 00+ cars you'll be left with a vacuum hose that you'll need to plug up.
Buy your headers with some kind of ceramic coating or get stainless steel. If you cant afford coated headers hold off until you can. If your car see's alot of winters (real winters; i.e. east coast and mid west, ect) you might want to seriously consider the stainless steel headers, they are more expensive then ceramic coated headers but the chance of rust will be greatly diminished.
Old 08-03-2004, 11:20 PM
ohhiitznik's Avatar
those macs will fit you car, all emissions are already blocked off, so just delete your emissions and youll be all set.
Quick Reply: 98-99 setup vs 01
