Change oil indicator flash when engine starts
Usually I take it in to the dealers, but I did the oil change myself, and I was wondering how to reset the computer so that the change oil light doesn't come on anymore
Originally Posted by Hot02SS
I think you turn the key to RUN, then hold down on the trip resest switch.
Thanks-
The trip reset switch by your odometer. turn the key to the run postion and hold the trip button till the oil change light starts flasing and then goes out...then turn the key to teh off position and start it back up...you'll be all good
Thanks Guys-
LS_Wang, I feel like a dolt, I thought by the term "Trip Reset Switch", you meant a circuit breaker trip reset in one of the access panels. Thanks for the help.
No wonder I couldn't find it in my Chilton's....
1. Turn key to the "on" position but don't start car
2. Pull the PCM BAT and PCM IGN fuses in engine compartment
3. Wait approximately 5 minutes
4. Turn ignition off
5. Replace fuses
6. Start the car and then make sure the light has gone off
it works for ses lights it might for the oil change light to
5. Replace fuses
