My car is idling at 950 RPM, is that right?
Old 04-09-2006, 12:21 PM
ssmaro's Avatar
Default My car is idling at 950 RPM, is that right?
Well the other day I finially got my SS out to wash it. Well when I started it I noticed my RPM's were running a little lower than usual. Or at least I think so. What should the Rpms be?
Oh and I flushed the radiator out last weekend if maybe that has anything to do with it.
Old 04-09-2006, 03:18 PM
'Trust''s Avatar
Thats acutally a little high, mine idles around 800 and its raised because of the cam, and the fact that its an auto. You should be a little lower, more like 600-700RPMs, is this just on a cold start or all the time?
Old 04-09-2006, 04:40 PM
Shallow Bay's Avatar
No way. Considering its an M6, 950 RPM's sounds about right.
Old 04-09-2006, 05:37 PM
JD_AMG's Avatar
Mine idles at like 750(when warmed up)
Old 04-09-2006, 05:53 PM
LS144's Avatar
What about an A4 whats normal for it?
Old 04-09-2006, 05:58 PM
c0ncEpT's Avatar
500 for a stock motor
Old 04-09-2006, 06:00 PM
2001NBMZ28's Avatar
Warm on a scanner before tuning mine was 525-585 in gear, 645-676 in Park/Neutral.
Old 04-09-2006, 06:01 PM
LS1obsession's Avatar
Mine idles at 990-1,000 all of the time (m6), so sounds about right?
Old 04-09-2006, 07:17 PM
stevespewterZ's Avatar
My A4 always idles around 500
Old 04-10-2006, 02:47 AM
Moderator
nhra-trans-am's Avatar
mine idles around 600
Old 04-10-2006, 04:47 AM
300bhp/ton's Avatar
Don't none of you guys read the manual. It states ~650rpm and does not specifiy auto or manual.
Old 04-10-2006, 05:21 AM
99FormulaM6's Avatar
mines 850 (tuned w/ ls1edit)
Old 04-10-2006, 05:24 AM
4sconcepts's Avatar
just going to state that mine idles at 1,000rpm though
Old 04-10-2006, 05:56 AM
300bhp/ton's Avatar
Is your car stock?
It should idle higher on cold start up until it completes it's cold start cycle.
At full operating temp it should have a much lower idle, 1000rpm is way too high. Is there a chance your tacho is wrong?
A Rover V8 idles at ~850-950rpm and every other car I've been in idles below 1000rpm. I admit my TR7 tends to idle at 1000-1100rpm but that's more due to the setup of the cam/carb and the faster idle doesn't really hurt it, but it could do with dropping a few 100rpm.
Old 04-10-2006, 08:20 AM
stokedporcupine's Avatar
my m6 idles at 650 in neutral. always just assumed that was normal, lol, guess it is.
Old 04-10-2006, 08:26 AM
777's Avatar
Everybody the tach's are not accurate in these vehicles. Mine shows me idling 1000-1100rpms however I'm really idling ~800 (via scanning software). I agree with the 650rpm idle. That sounds about what it should be.
Old 04-10-2006, 08:38 AM
Board Certified Idiot
Z2K_MrJ's Avatar
Most will Idle around 900ish when 1st started up. when warm most should Idle at 500ish.
Old 04-10-2006, 08:44 AM
98camaroLS1M6's Avatar
98' tachs reads about 150rpms high. My car stock(M6) read 950 but was actually 800. 500 to 650 is normal for an auto usually 550 in gear. With my cam, it's about 850-900rpms.
Old 04-10-2006, 09:51 AM
jmm98LS1's Avatar
Stock warm idle---
a4: 550 in gear, 650 park/neutral
m6: 750
Don't pay attention to what your tach says......they all suck.
Old 04-12-2006, 10:46 AM
senicalj4579's Avatar
mines an a-4 and idles at 750 warmed up
Quick Reply: My car is idling at 950 RPM, is that right?
