How can i make a 900+ rwhp trans am street legal?????
Old 10-19-2006, 11:56 AM
ebaker's Avatar
Default How can i make a 900+ rwhp trans am street legal?????
Heys guys im about to start building a street/strip twin turbo trans am that will have 900+ rwhp. So what all do i have to do to the car to make it street legal???? Is it even possible???? Thanks in advance guys!!!!!
Old 10-19-2006, 12:19 PM
BrandonDrecksage's Avatar
it all depends on your area with emissions. If they have any type of tail pipe testing..your gonna have trouble. If they just check to see if you have cats then your good to go. I hope you have a ludriciously amount of money. Built eeing, tt kit, rear, tranny, clutch..ect. not to mention all of the labor. good luck.
Old 10-19-2006, 12:57 PM
MikAbtII's Avatar
Most states that have state inspections have moved to OBD2 tests, so you'll need to have a factory computer that can set and pass readiness codes, not to mention a car will not pass if it has any trouble codes commanding the check engine light on. Also most state inspections involve a visual check for all emissions parts that came on the vehicle from the factory, i.e. secondary air, all o2 sensors, cats, egr, etc. Or just find a state inspection place that will inspect it with the six pack in the passenger seat.
Old 10-19-2006, 01:56 PM
nebraskaTA's Avatar
Or move to a state that doesn't have inspections.
Old 10-19-2006, 02:15 PM
ebaker's Avatar
well i live in texas so i think i should be ok. there is a mom and pop shop right down the road and my truck passes with hardly any interior and no cats.
Would a cop get pissed if i have a cage in the car????
Old 10-19-2006, 02:24 PM
ebaker's Avatar
Is it actually against the law to have a 900+rwhp car on the road???? If not im not even going to worry about it????
MrDude_1's Avatar
depends... did you **** the cop off before he saw your cage?
Old 10-19-2006, 02:58 PM
98Z28MASS's Avatar
bribe the inspection station you go to
Old 10-19-2006, 02:59 PM
ebaker's Avatar
well i know i can do that, but the only thing im worried about is if i ever get stopped i dont want to get in trouble for having a cage or anything like that.
Old 10-19-2006, 03:17 PM
WarShrike's Avatar
I know of quite a few people who drive street cars here in TX that don't get in trouble for a cage. It's safety equipment for pete's sake. Just don't do anything to **** off the cop in the first place and you'l be okay.
I don't think there's a HP limit for street cars either. Just do what you want with the car, but don't be an idiot and screw around with the car in public (especially around other civilians/bystanders).
Old 10-19-2006, 03:18 PM
Ericbigmac83's Avatar
Theres nothign wrong with having a cage
ebaker's Avatar
thanks guys, bc i have been hearing some talk about if i were to get stopped and the cop saw the cage he could make it to where i couldnt drive the car on the street and could only be driven at the drag strip.
Old 10-19-2006, 03:25 PM
98Z28MASS's Avatar
Yea you shouldnt get hassled for a cage as long as you will pass a visual inspection. If you need cats then run them and have dual cutouts or run gutted cats. If loudness is an issue then just run a real quiet catback or dual system. I know purevil runs his 800+ signle turbo 408 iron block camaro on the streets all the time. He is in the eastern section of this board.
Old 10-19-2006, 03:28 PM
bww3588's Avatar
the bad thing about having a cage, if you wreck the car on the street and you dont have a helmet on, your liable to wack your noggin on the steel cage........
Old 10-19-2006, 03:42 PM
2002blackZ's Avatar
Or you could just wear a helmet all the time too and the cops will most likely leave you alone because they'll think you're nuts...
BTW, I've never heard of a HP limit. I think its mainly just the factory safety equipment, emmissions junk, lights and turn signals. I think there is also some states that enforce cracked windshield regulations. Best bet would probably call the local authorities and ask.
Good luck with your project!
Old 10-19-2006, 08:26 PM
ebaker's Avatar
thanks for the info guys!!!!!
Old 10-19-2006, 11:57 PM
DoubleTapDrew's Avatar
Put foam cage wrap on the cage near your head. You shouldn't have any problems. There is no 'hp limit'. You could have a 10,000hp car if you want, as long as it doesn't break any safety or emissions laws.
Old 10-20-2006, 12:05 AM
ebaker's Avatar
thanks man!!!
Old 10-20-2006, 12:25 AM
carado1984's Avatar
the question is.. how much are you willing to spend.. 20g+? built motor stroked and forged 8k at least for a 400+cu in. 8k on a twin turbo kit, at least... 2k + rear. 3k+ tranny more if its stick.. suspension wheels tires 2.5k+.. it would be cheaper for forged iron 408 and some nitrous but it would be tough to reach that goal unless youre using over a 300 shot.. go ask some guys in the turbo sections what there setups cost.. see if you can find a guy with a maple red metallic trans am conv. non ram air.. really nice car..
Old 10-24-2006, 03:25 PM
wilddawg's Avatar
lots of cash and bribe the emission guy for a sticker cause twins turbo at a safe air fuel ratio aint gonna pass emissions
