obtaining 11s........
Old 10-31-2006, 09:22 AM
nseldy's Avatar
Default obtaining 11s........
With my current mods I think my car is capable of 12s. I was wondering what some of your thoughts were towards having an 11 second N/A daily driver car. Would it be possible?
My current mods are listed in my sig. I wanted to keep the stock heads, and I'm hoping with an upgraded valvetrain, gears, and of course drag radials I'll be close to 11s. I drive my car just about everyday and I don't want to sacrifice reliability, so does this sound realistic?
I did some research on cams, and I was leaning towards the TSP Torquer v.2, but I wasn't sure if that would be too big a cam for daily driving. I also was checking out some Comp Cams and found the 275Xtreme RPM seemed to work well. I know cam selection is very complicated and can be a long process, so I definetely don't want to throw in a huge cam just because it sounds choppy at idle.
If anybody out there has an 11 second daily driver, let me know how you like your cam. Thanks a lot!!
Old 10-31-2006, 09:29 AM
Cerebrex's Avatar
Throw on some some nitrous and retain stock driveability all day long
Old 10-31-2006, 09:55 AM
bjamick's Avatar
have you had your car dynoed?? we have bout the same mods exactly LOL
Old 10-31-2006, 12:10 PM
nseldy's Avatar
Nope, haven't dynoed yet. I figure I'll just wait for my valvetrain upgrade and get it tuned at the same time, just as soon as I figure out what the hell cam I'm gonna use....
Old 10-31-2006, 12:59 PM
staringback05's Avatar
moderate heads and cam, but a good tune also...youll get in the mid to high 11s
Old 10-31-2006, 11:54 PM
nseldy's Avatar
Doesn't anybody out there have 11 second N/A daily driver F-bodies?
Old 10-31-2006, 11:59 PM
So-GT0071's Avatar
I'm sure a good amount of people do.
That is good advice.
Old 11-01-2006, 12:21 AM
mattraypharbor's Avatar
I do...its great cam only set up...7.7s in the 1/8th high 11s in the 1/4 with two jl twelves in a heavy *** box...1.6 60's full weight with spare...
Old 11-01-2006, 12:22 AM
would be faster if i took that 200lb piece of crap system out of my trunk and not to mention the 90lb jack and spare...lol
Old 11-01-2006, 06:38 AM
BrandonDrecksage's Avatar
Full suspen with slicks and a built rear. Go from there, shoudl take to much more if you can hook up and get a low low 60ft time.
Old 11-01-2006, 09:12 AM
nseldy's Avatar
That's pretty good for a cam only car! So how do you like the cam for daily driving? What cam is it, and do you have the specs if you don't mind me asking?
Thanks!
Old 11-01-2006, 07:49 PM
bjamick's Avatar
what other mods do you have?? like intake, lid, cut out?
Old 11-01-2006, 08:49 PM
Camaroholic's Avatar
You really only need 3 big mods for an M6. 12 bolt rear end, a stout clutch, and a serious driveshaft. Drop some weight, do the standard lid/headers/exhaust, and you'll be very close. A cam will put you over the top (my car went 11.85 with a B1 cam - 221/221 .556/.556 114LSA). The way to get it is to drive it like you stole it. Seriously. On a stock motor, bounce that sucker off the rev limiter to launch it (assuming sticky tires). That's why you need the 12-bolt and clutch/driveshaft. Don't fear the gear. 4.30's or 4.56's are GREAT in a 6 speed.
Walk down the dark path... 4.56's are very, very fun.
Old 11-01-2006, 09:10 PM
LSGunZ28's Avatar
All you need is a Ls6 manifold, Ford 9" ( preferrable 4.11s) and Slicks. WIth all those you should be able to be 11.99s! without gears you may be 12 flats. But the tires are a must for a quick time. But you need a rearend also if you are gonna launch that high. So with slicks and a rearend and gears you should be able to accomplish 12 flats, thats why I said 11.99.
because without the rearend, or slicks, or the shifter and on a stock fried clutch and I dont have the bigger MAF, but I have an LS6 intake manifold. and LT and ORY with LM. I run 8.07 in the 1/8 and that is 12.5s in the 1/4 with a 1.89 60'
thats why with slicks if you can cut your 60 to a 1.7 you should be able to be right on the dot of 12. and if you powershift. 11.99 is accomplishable.
Old 11-01-2006, 11:06 PM
Thanks!
I went 7.5's today cam only muaahahhaha anyway ya i'll send ya the specs
Old 11-02-2006, 08:45 AM
nseldy's Avatar
OK, Thanks for the help....... Now for a decent street cam, How about the TSP torquer V2, is it too big for daily driving? I also plan on changing valve springs, pushrods, rockers at the same time.
I want to make sure the car stays reliable, but I also want as much peformance as possible. I guess it's hard to have both!!
Thanks Again
Old 11-02-2006, 11:23 AM
i have both
my car so far has always been reiliable even after all the **** i did to it..
Old 11-02-2006, 01:47 PM
nseldy's Avatar
Great...I'm glad to hear it's easily attainable!
Old 11-02-2006, 05:57 PM
01_ram-air's Avatar
tr224/224 114 LSA. good cam, very streetable.
Auto's and 6 speed guys are a little different due to the launch.
I run 7.7s on motor, 12.2s in the 1/4
Nitrous is the best bang for the buck.
7.1s and 11.2s
Oh, did I mention that my motor is stock.
