oil change light
oil change light
My wont my oil change light go off? I went about 3500 between the last oil change and it came on on the way home from the parts store to change it and now it wont go off. How do you get it to go off?
Did you reset it after the last oil change? Turn key to RUN, don't start car. Press and hold the trip/oil reset button on the dash for a few seconds until it goes off.
Mine has only come on once since new, only 25K and a few battery and frequent tuning changes - don't know if that affects the GM Oil Life System or not - so I don't trust it. Manual says it can come on anywhere from 3-10K.
Originally Posted by Z2K_MrJ
Turn Key forward Once.. Then Push the Trip/odometer Button in & hold for couple of Seconds.. Should Go out.. This Lite will come on every 3kMiles
Originally Posted by BriancWS6
All the ways to turn it off are correct, but the amount of mileage that it comes on will vary due to it going by how the car is driven, idle time, etc, to help determine when to set the light.
Read the owners manual folks.
Originally Posted by Hoss Ghoul
Exactly, driving style is what determines when the light will come on. There is no oil analyzing whatsoever it is merely a program that takes sensor readings into account.
Originally Posted by 2001NBMZ28
Anyone know for sure if resetting the PCM or retuning the PCM automatically resets the GM Oil Life System? Thinking it does????
Obviously having a dead battery doesn't delete your tune, so some things are protected, not sure if oil indicator light or PCM codes fall into this category?
Good questions though.
