Running Too Long?
Running Too Long?
This may sound like a dumb question, but I started my car to warm up before I left work. Well, i got stuck talking for awhlie nd before you know it, 40 min. have passed. The question is can letting the car warm up for that long hurt anything?
Besides gas! I usually don't let warm up for more than 15 min.
just watch the temps... as long as it doesnt over heat or for whatever reason lose oil pressure you are just fine. this girl i know left her car on all day while she was at work. i am talking over 6 hours straight running in the parking lot. no lie and hers was just fine.
LS1Tech Administrator
Received 1,492 Likes
It won’t hurt anything once in a while, so long as the motor doesn’t overheat. I wouldn’t do it every day just due to the waste of gas and probable carbon build up on the plugs, etc., but it’s not a big deal on occasion.
Example:
I’ve been storing LS1 cars every winter now for the last 8+ years. Usually once a month during the winter months, I start the motor and let it run for a total of about 30-45 mins. Once the coolant is warm, I’ll bring the rpms up to about 2000 (no more than 2500) and hold it for a few mins just to heat the oil further. I also run the A/C system to lubricate the seals, preventing leakage of the freon. After all these years, it’s never caused a problem. In addition, I usually try to heat the garage up to 40 degrees or so before starting the motor, that way it warms up quicker.
I know some people prefer to let the motor sit unstarted during storage because they are concerned about moisture in the oil, but I’m from the other school of thought. I don’t like the idea of the rings sitting on the same spot on the cylinder walls for 4-5 months during storage. Also I like to get a fresh coating of oil across the internals and run the A/C system. Starting once a month with a 30-45 min run time has been working great for many years of storage now. And I never have any signs of moisture build up on the underside of the oil fill cap either, nor does the oil ever have that milky white cream that usually comes with moisture contamination. I use good quality synthetic oil and change it often.
Example:
And yes, this is a topic that comes up a LOT.
I remember one time I came home from work and had a hand full of things to carry so I brought them inside well I forgot to go back outside and turn of the car and left it on all night till the next morning when I was running around the house looking for my keys. When I went outside the car was on. The only thing it did was burn a shitload of gas. That was when I first bought my T/A.
I started up my Civic the other afternoon to warm it up and forgot all about it and it ran the next morning till 6 am. 15 hours it ran with the heater cranked on high. Used almost 1/2 a tank of gas. Checked all the fluids, drove it and it was fine. Hope I never do that again.
Our cars are capable of going WELL over 150,000 miles I'm sure sitting at idle did little to your car and probably not going to overheat in this **** cold weather we are having now. Gm puts them on a dyno forever testing them before they even put them in cars and some they run till fail for hours at full throttle. Hell I bet 20 minutes in stop and go is worse on your car then letting it idle for 40 min. Your fine.
The answer to your question is NO. Letting it warm up that long won't hurt anything. Even in the summer on the hottest day in Death Valley.
Lots of cars get stolen that way though!
Originally Posted by 300bhp/ton
Yeah I bet GM never thought to test a car ticking over for 40 mins
This IS the newbie section...I suggest you only post if you have something even remotely helpfull.
On the other hand this thread has come up alot and no it will not hurt anything but like other members said watch your temperature, etc.
I understand your car is your most prized possesion and you want to take care of it, but the search engine will help you alot and will protect you before all the bench racers come here to scorn you.
Next time .....or just PM me if ya need ANY help
Thanks
Ls1tech.com Staff
