Ticking after oil change?
I Just did my oil change last night and I put in some fresh Royal Purple
10w-30 with K&N oil filter and 1 qt of lucas syn oil stabilizer. This is a fully synthetic blend. Noticed I can hear the valves a bit more on this oil. Has anyone ever got that? I dont know what oil it had in it before, but smelled like non synthetic. What do you guys think? Is it a problem. It ticks at the rate of a valve opening and closing. "Click, Click, click, click, click, etc."
Do a search on Lucas oils on here, I've read some bad stuff about it.
Read this post: https://ls1tech.com/forums/showthrea...ighlight=Lucas
I use 5- 40 Mobil 1 and my ls1 doesnt tick but it will knock if you automatically put the car under a load after start up, I have to let the thing warm up for atlest 20 min before drivin, gets aggervatin sometimes, I have asked some guys on here about the situation and the have told me that the Ls1 are notorious for this issue.
i just bought my ta about 1500 miles ago i found out that the person before me had put some lucas in it... the motor made no noises but on idle my oil press was good but erratic at idle (just under the 40psi mark and 50 ish above idle) i went straight to autozone to get some more seafoam ( i just did the intake) ran it in the oil about 50 miles and then changed the oil with a k&n oil filter and full syn 5w30. the motor seems too like me a little more and now oil pressure is excellent (just above 40 at idle and 65 ish above that) and does not act erratic DO NOT USE THAT LUCAS CRAP!
Originally Posted by WS6 Rampage
+1 for German Castrol 0W-30. Thin as **** but I haven't had any issues.................yet!
