ok this squeaking noise is back
Well i have this problem. i hear this squeaking / chirping noise cokming fomr my car. it come form around the front of the engine. it is going to make me go crazy. i have no idea what it is. i think i am going to change the belt.
When i am at idle it is only a slow chirping/ squeaking noise, but as i begin to go faster it does as well. please help i cant take much more.
Thanks
Thanks
If it a whinning noise... Check your battery and alternator and your powersteering fluid.. I had this same problem... My battery was discharged and my fuild level was low.. So try that and see what you get... Mine still comes back warming up though but not nearly as much or as bad
I second the pulley. My car would do that, especially when wet. During my cam install I found that the idler pulley for the A/C system was nearly shot. Have not started car since but should cure the problem. I've had a couple other cars that have had the same problem with either the idler pulley or tensioner pulley being the fix. Just make sure you figure out which pulley it is
Take the belt off with the engine off and try spinning the idler pulley. Check for play in all the pulleys on the waterpump, ac compressor, power steering, and alternator. Check for in/out play as well as lateral movement. Any play at all indicates the bearings are shot. Inspect the belt really well too.
Another item to check could be the AIR pump under the driver side headlight....
