Did I spin a bearing!!??
Old 08-08-2007, 07:30 AM
hasenbonkers's Avatar
Default Did I spin a bearing!!??
Ok, goin to work yesterday. pay toll, and as soon as i leave i stomp it and fly to round 50 mph. then i just cruise and i hear this noise, it sounds like an exhaust leak! Im like WTF. so i get to work and check things out, its a rattling sound, like something is moving around, but it sounds like its coming from Inside the engine but i cant tell, its not too loud. But everyime i drive it sounds like a leak from the header. any one kno wut this could be. ill try to get a video a lil later
Old 08-08-2007, 07:55 AM
95GreenZ28's Avatar
Yea post a vid. It could be several things. May have just bent a pushrod.
Old 08-08-2007, 10:17 AM
sworaz's Avatar
Sounds like a header leak
Old 08-08-2007, 11:01 AM
tengtou's Avatar
if it makes a noise like this: clunk clunk clunk clunk
then u spun a rod bearing
Old 08-08-2007, 11:50 AM
ls1leadfoot's Avatar
Spun Bearing.....mine Done The Same Thing....only Other Thing It Could Be Is A Collapsed Lifter Or Bent Pushrod......change Your Oil....if It Looks Like Metallic Paint With Metal Shavings.....you Have Spun A Bearing My Friend....
Old 08-08-2007, 12:09 PM
98Camarod's Avatar
A spun bearing normally is a knock and does it no matter what. At idle it will knock and it will increase with the rpm, that is bad for business. A collapsed lifter is usually faint at idle and when you rev it it will clank where ever the collapsed lifter is back down to idle.
Old 08-09-2007, 06:24 AM
KENS_SS_4's Avatar
A spun bearing is REAL LOUD. When you hear it you know your car is broken.
So it is not a spun bearing.
Old 08-09-2007, 06:38 AM
aggie-chase's Avatar
Probably just an exhaust leak, how many miles are on the car? Post video or sound clip if you can.
Old 08-09-2007, 09:03 AM
Thule's Avatar
now my english skills get in the way, but you can know spuned bearing sound by couple of things,
when its not that bad, it dont knocks when the car is cold, and start knocking when the oil get hotter,
bend down and notice if you can hear the knock sound from under the car to,
push the throttle and let it go, when you take your foot of the throttle the knocking should get a littlebit higher, crankshaft bearings knock highest when the "force" is neutral,
Old 08-09-2007, 09:34 AM
TX_SS's Avatar
header gasket..
Old 08-09-2007, 10:15 AM
the_merv's Avatar
That's an Exhaust Leak, or a Lifter Ticking..I am goin with the Exhaust Leak.
You will know a Spun Bearing..the whole thing would be clunking..
Old 08-09-2007, 05:44 PM
I got a http://youtube.com/watch?v=p8FHYceG0Y0. What do u think it is? Could u deaden the sound by putting in heavy duty oil?
Old 08-09-2007, 06:32 PM
SHINER's Avatar
sounds like header leak/piston slap to me. Putting heavier weight oil will make the sound even louder.
I think your fine, any decrease in performance?
Old 08-09-2007, 08:54 PM
no, no decrease in any performance
Old 08-09-2007, 09:12 PM
Blackhawk777's Avatar
I have that same kind of noise, but I'm wanting to think it's lifter noise.
Old 08-10-2007, 01:52 AM
the_merv's Avatar
Sounds like a Lifter..use a little bit heavier Oil.
Old 08-10-2007, 07:11 AM
so, how do i go about correcting the problem, if it IS in fact, a lifter. Just add a little bit of heavier oil, also i am about 1000 miles OVER my oil change, if tht has anything to do with it.
Old 08-10-2007, 07:40 AM
SHINER's Avatar
You can only "hide" a sound for so long before the problem starts to spread and affect other parts. An engine has many parts that work harmonically and if one goes bad, the rest of the stuff starts going bad. Next thing you know your cam lobe is showing excess wear and scarring, then your cam bearings take on more stress.
The BEST thing you can do it pop the valve covers off remove the rocker arms (10mm) and take ALL the pushrods out and roll them on a flat surface. If any of them wobble just the slightest it can do some damage later on down the road.
Im betting you have some bent pushrods.
Check out TSP, they have some Comp cams Magnum rods that they put their names on, and are .080 thick(I believe). Great pushrods, and take much much more abuse.
When you put your rocker arms back on torque to 22lbft.
Old 08-10-2007, 03:24 PM
*Problem Fixed* Went to my local Tuffys, and all it was, was the heat shield by the headers, both the bolts had wobbled loose, and was rattling. Sure sounded like it was coming from the engine, but its all fixed, and they didnt charge me!
Old 08-10-2007, 05:06 PM
while were on the subject, what causes u to spin a bearing? Because I always hear people s aying they were brake torquing it, or stompin on it a lot, and people would say "that's what u get for doing a burnout" or something like tht. So how can you avoid spinning a bearing?
Quick Reply: Did I spin a bearing!!??
