Question about 241 and 243 heads.
Old 08-23-2007, 11:23 AM
ranger2339's Avatar
Default Question about 241 and 243 heads.
Ok so I bought a longblock from a guy, he said it was a LS6 longblock. So I had the machine shop rebuild it etc... Well we just noticed now, that the heads are stamped with 241?? That means its a LS1 right?
What are the block numbers also?
LS6 heads are 243's?
Thanks
Josh
Old 08-23-2007, 11:42 AM
tylerdj's Avatar
Right, 243 are the ls6 heads and 241 came on 00-02 ls1's
Edit: not all 2000's had 241's, some had the 853 castings
Old 08-23-2007, 11:52 AM
Sharpe's Avatar
I don't know the answer to your question, but just want to add that if you had them ported, there is next to no difference between the 241's and 243's, I've read.
Old 08-23-2007, 11:58 AM
SHINER's Avatar
Sounds like you didnt get a LS6 block.
I wouldnt waste anytime with 241's.
Old 08-23-2007, 04:31 PM
ranger2339's Avatar
Thanks.
Well the heads have some mild work done to them, so maybe I will use them for now and then when I have the money get something better than LS6 heads.
We have to get this engine in the car, so we done have any time for a head swap.
I am kinda mad now, damn it!
Anybody know the numbers for the LS1 and 6 blocks, then ones on the block?
Old 08-23-2007, 06:23 PM
SHINER's Avatar
the LS6 block is much darker in color than an ls1 block. The LS6 will be a very dark grey block. Go get me the number off the block and il tell you what it is.
BTW contact Jon Reynolds of TSP they got those 5.3L ported heads and people are seeing very very good results, and they come assembled with ferrera race valves, and dual valve spring set up I gained about 42 rwhp with them.
Old 08-23-2007, 06:44 PM
raills1's Avatar
look in the stickey under frequently asked qustions it has the block numbers.
Old 08-23-2007, 08:00 PM
98Camarod's Avatar
Word. I wouldn't really be worried about it unless you paid too much, then I'd be all over his ***. But it's really your own fault for trusting them.
Old 08-23-2007, 08:57 PM
ranger2339's Avatar
Ya well I even asked the guy again and he swears up and down its a LS6, he said he ran the numbers opn the block and it came as an LS6 block..
Ohh well my mistake for sure, i just wanted to make sure that I had the numbers right.
Old 08-24-2007, 02:34 AM
floman's Avatar
The last 4 numbers on a LS6 block will be 1168. Some of the later 2002 f-bodies had the LS6 block with the 241 heads. The 243s only came on LS6 engines in ZO6 Vettes and then later on LS2s also.
Old 08-24-2007, 07:34 AM
troopercar's Avatar
Didn't you look at the engine before you bought it? The heads have 241 right up front. Like stated above, could be LS6 block with LS1 heads. I'd rather have worked LS6 heads than block.
Old 08-24-2007, 08:56 AM
sixvi6-camaro's Avatar
How to Tell if you have an LS6 Block
Old 08-24-2007, 12:34 PM
Sharpe's Avatar
It might be an LS6 BLOCK and not be an LS6 engine.
Some of the last F-Bodies got LS6 blocks I think with all other LS1 parts, including 241 heads, but I could be wrong.
