$2500 dollars
$2500 dollars
just traded my 70 camaro 383 for my 2000 Camaro SS m6. i want the old school cammed sound and fast horsepower. my budget for the time being only a mere $2500 including shop labor (not enough time or workspace of my own) only mods on car now are torque arms eibachs and lowered.https://ls1tech.com/forums/newthread...newthread&f=4#
Mullet
Mullet
I think most speed shops charge around 1500-1600 for a turn key cam swap. Turn key meaning everything you need to install the cam, the install and tuning. Also, get some headers installed at the same time and that should set you up nicely. Keep in mind that adding power could cause some stuff to break. So make sure you have cash to fix something. i.e. if the rear end breaks or more than likely, the stock clutch(if its still stock) will start to slip.
Originally Posted by TA1364
I keep seeing posts where ls6 intakes are $300, where the hell do you get that? The slp with egr is 5XX
