Header Install!!
Old 10-05-2007, 02:37 AM
odarabla's Avatar
Default Header Install!!
I am going to try and install my Hooker Lt's and y-pipe this weekend. I never even seen this done before. How hard is it to do? Has anyone done there own set of Hookers and can give any advice? I've heard that the Hookers fit really well. Is there anything I have to move? Any help at all would be appreciated. Thanks in advance.
Old 10-05-2007, 03:09 AM
brianfromhawaii's Avatar
ls1howto.com may have it, i suggest you try a search.
Old 10-05-2007, 03:23 AM
odarabla's Avatar
I did a search only found shorty header install and LS1howto.com only has it on a C5. But thanks
Old 10-05-2007, 03:34 AM
wzup1000's Avatar
look around in the GEN III External Engine Forum, there seems to be at least 2-3 posts for header installs a day...
Old 10-05-2007, 03:43 AM
odarabla's Avatar
Ok thanks.
Old 10-05-2007, 07:18 AM
99blancoSS's Avatar
Not hard to do. Do yourself a favor and the night before use penetrating oil on the y pipe bolts and clamps. You might need to move your starter. Taking your coil packs off helps.
Old 10-05-2007, 07:33 AM
teke184's Avatar
page 11 of this website....should help all you need:
my site
Old 10-05-2007, 09:03 AM
odarabla's Avatar
my site
Of what web site?
odarabla's Avatar
Csn it be done off of jack stands? I have a set of 16" jack stands to work under.
Old 10-05-2007, 10:10 AM
99blancoSS's Avatar
debateable. The higher the better is the motto. You could build platforms for your stands if it isnt high enough. 2x4's nailed together stacked is good as well
Old 10-05-2007, 02:11 PM
odarabla's Avatar
Ok. Here it is. I got the stock manifolds and Y-pipe out. I have the drivers side header bolted in but I do not have the car high enough to get the passenger side in. Does anyone know if it can be put in from the top?
Old 10-05-2007, 02:33 PM
aaron653's Avatar
negative. get the car higher somehow
Old 10-05-2007, 04:53 PM
blk97z28's Avatar
On my lt1 we went from the top and it was cake!
Old 10-05-2007, 05:40 PM
blkZ28spt's Avatar
In from the top is hard, and I don't know if it's even possible with Longtubes.
You need to get the car high, as stated above.
I installed my Jet-Hot longtubes from the bottom on jack stands. Many other people have as well. You just have to get the front end high enough to put the headers darn near vertical when you first slide them up. I even lifted the rear of the car a little bit in order to help get the front higher.
Make sure the stands are secure before getting under the car.
Old 10-05-2007, 06:15 PM
JScamaro's Avatar
I went and bought some jack stands meant for suv's. They jack up pretty high and it was enough to install my headers without having to support them with anything to make them higher.
Old 10-05-2007, 06:59 PM
odarabla's Avatar
Thanks guys for all your help..
Old 10-05-2007, 07:54 PM
blk97z28's Avatar
well on PS we undid the PS motor motor used a bottle jack it went up 2in and it slide in great. DS from below and PS in from the top IMHO. Devin
Old 10-05-2007, 09:12 PM
The Black Mamba's Avatar
I didn't read through the whole post, but make sure you get yourself some new gaskets.
Old 10-05-2007, 09:20 PM
blkZ28spt's Avatar
You shouldn't need new gaskets.
One of the few reusable gaskets. They are metal. Most people re-use them and I havn't personally heard of any problems yet.
Old 10-05-2007, 10:06 PM
LS7jUnKiE's Avatar
.....lol im glad i have a lift!
