cutout open or close?
Old 11-21-2007, 02:48 PM
myfirstgm's Avatar
Default cutout open or close?
going to the track tonight to see what the car will do with the longtubes and offroad y pipe.car has a borla catback with a cutout.
Old 11-21-2007, 02:49 PM
youngrigo's Avatar
Open!!!
Old 11-21-2007, 02:50 PM
chavez885's Avatar
both,do one run with cutout open,one with it closed
Old 11-21-2007, 02:56 PM
MJK
MJK's Avatar
If you have the adjustable Borla,isn't it basically a cutout already when using the wide open plate?Or actually no plate?
Maybe there would be a difference between the closed borla and an open cutout?
Old 11-21-2007, 03:40 PM
myfirstgm's Avatar
i dont think i have the adjustable one
Old 11-21-2007, 06:05 PM
MJK
MJK's Avatar
Aaahhh ok...Good luck at the track man!
Old 11-21-2007, 06:17 PM
95 Z28's Avatar
Get yourself a baseline run with it closed, and try to duplicate that run with the cutout open and see if you pick up any ET or mph.
Old 11-21-2007, 06:19 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Thumbs up
Old 11-25-2007, 12:03 AM
TLUZLS1's Avatar
What did you end up running? I bet you would have a better 60ft with it closed but a lower trap speed, but in the end I bet having it open would give you better results. I always just run mine open. Just experiment with it.
Old 11-26-2007, 07:21 PM
Reject's Avatar
probably run the same time if not alitle more slower just more noise with the cutout open
Old 11-26-2007, 07:25 PM
NHRAMAN's Avatar
Exclamation
SLOWER....... NOT LIKELY................... Probably 3-4 tenths FASTER.
Old 11-26-2007, 07:30 PM
waldershrek's Avatar
That's what I'd do for my own little bit of knowledge
Old 11-26-2007, 07:33 PM
Cobra2WS6's Avatar
Maybe 1-2... 3-4 seems a bit excessive
Old 11-26-2007, 07:35 PM
Reject's Avatar
1-2 seems a bit excessive
Old 11-26-2007, 09:39 PM
RE AND CHERYL's Avatar
I'm there, if he got a solid 1/10 I'd be happy.
Re'
Old 11-26-2007, 10:36 PM
ms4z28's Avatar
forget cut-outs jus get a 3in ORX they flow and u still keep back pressure so u dont lose torque
Old 11-27-2007, 06:52 PM
myfirstgm's Avatar
haven't ran the car yet,track was closed last week.might go tomorrow i'll let ya'll know the results.before exhaust car did 13.6 @104 spinning the tires in second.hopefully i can learn how to launch the car for better 60ft times.
Old 11-27-2007, 07:02 PM
ms4z28's Avatar
best u can look at on street tire is a 2.1 60 ft
Old 11-27-2007, 07:10 PM
SmaknaSS's Avatar
I also say run a few passes with them closed and then a few open to see just how much you gain.
you will be faster with them open.
Old 11-27-2007, 07:31 PM
myfirstgm's Avatar
that sounds about right my 13.6 pass was 2.25
